Just a quick update - flywheel back from the machinists no fuss same day turnaround - $60 - Now fitted with new bolts ($72)
New clutch now on the beast $290 - ready for the boxing match tomorrow - gear boxing that is.
only issue is a small amount of wear on the thrust release bearing arm - the three pics show the piece of metal that clips over the arm and the thrust bearing clips onto each side and the bearing pivots on the bit of metal. Its a bit worn but doesn't seem to stop the bearing changing angle as the clutch is pressed.
Would like to change them out (2 - one each side) but can't find them listed as a part.
The are hardened spring steel by the look but couldn't cost much ...
Does anyone know if they are available or maybe this is a standard 'bit' that any clutch place would have ?
New lower ball joints ready to go on but mate suggested that I refit the old one first and drive it to see if the cv's are ok then put the new ones on if the cv's are ok else swap out the cv's and add the new ball joins at that time !
Busy day tomorrow !
Busy day tomorrow !
