I have a bit of a dull rattle sort of noise coming from the R/H side, front of the veichle. Feels like its either in the suspension, steering or wheel bearing. Can sometimes feel it through the floor/pedals with your feet. Makes it at various speeds, mainly when the front is under light load, ie not cornering etc and mainly on slightly rough bitumen roads, like typical outback country roads.
Ive gone over all the bolts/nuts i can find under the veichle, all tight. Jacked it up each side at the front, only thing i could find was a slight bit of play in the front R/H wheel bearing when grabbing the wheel at the top and bottom and rocking it. L/H didnt move at all. Could this be it? Are the bearings serviceable? I pulled the front wheel off and the hub all looked pretty sealed up and maybe not serviceable.
Its a 2010 Crafter with 50k on the clock.
Thanks,
Thanks,
