. Innovative Technology with the VW NGD 370 engine
. Strong, modern and comfortable models
. The market’s best cost effectiveness
. Traction options: 4X2, 6X2 e 6X4
Volkswagen Trucks and Buses presents to Brazilian fleet owners and carriers additional three models of trucks from the Constellation line. The vehicles VW 19.370, VW 25.370 and VW 31.370 arrive at the market through a brand’s world launching. Technology, productivity and the best cost-effectiveness still guide the philosophy of Volkswagen products, a company that along four and a half years is leading the domestic sales of trucks over five tons of total gross weight.
The big news is the arrival of the 367 horsepower VW NGD 370 engine with several technological improvements. Developed by Volkswagen Trucks and Buses, and produced by MWM International, the new motor running is the result of 38 thousand hours of engineering work and over 3.5 million kilometers of tests in the roughest conditions. The new Constellation trucks employ the VW NGD 370 in the versions mechanical horse 4X2, mechanical horse 6X2, and rigid chassis 6X4.
Such launchings provide the Constellation line with nine basic models from 13 to 57 tons of total gross weight, and may be acquired with cabins in versions bed or extended. Adding optional systems such as the VOLKSNET hybrid system (via satellite and cell phone) for fleet tracking and management, the Volkswagen original accessories, the VOLKSTOTAL plan of post sales assistance, the 24 hours free assistance in guarantee CHAMEVOLKS, and a net of 142 authorized dealers throughout the country, the brand enhances the number of solutions in custom-made transportation for the consumer.
Clients may also choose the versatility of the light Delivery Trucks and the strong and recognized Worker line that add 19 basic models to the Volkswagen Trucks family. All designed and assembled in Resende (RJ) plant that also incorporates the World Center for Trucks and Buses Development of Volkswagen Group.
Brazil: growth pushes the Trucks industry
An exceptional crop of grains, the accelerated growth of the oil extraction and the production of biological fuel demand more agility and skill for cargo transportation among farming, industrial and ports zones in Brazil. The Plan for Growth Increase – PAC – of the Federal Government, the new impulse in Brazilian civil construction through governmental incentives for self-owned homes, and the cattle breeding industry due to the development of the export of beef and its by-products are enhancing the Trucks market expansion in 2007.
Additionally, the Brazilian Transit Council – Contran – edited the resolutions number 210 and 211 establishing new limits for weight and dimensions of vehicles traveling by road and rail networks. One of the most important measures has established the increase of the combined total gross weight – PBTC – from 45 to 57 tons to use articulated vehicles, tractor and tug vehicles with two units.
Once more, Volkswagen Trucks and Buses meets the market requirements by increasing its competitiveness thus providing new alternatives to its clients. And such alternatives came through three new members of Constellation family: VW 19.370, VW 25.370 and VW 31.370. The brand is now in an intermediate segment between 300 and 400 horsepower.
VW NGD 370 motor, the category’s most innovative one
The VW NGD 370 engine presents pioneering characteristics to the heavy trucks sector. The high “flat” torque at low rotation is improved by a variable geometry turbo-compressor: the Multi Turbo System - MTS. The cylinder head with four valves by cylinder, the 9,354 cm3 (9.3 liters), 367 horsepower at 2000 rpm, and the Dual Power Brake – DPB – are additional characteristics.
The new motor running counts on an exclusive injection system, the Hydraulic Electronic Unit Injector - HEUI – at high pressure, with electro-hydraulic digital injectors and extended durability, developed by the partner company Siemens/VDO. This new motor running is lighter than the motor running of its direct competitors, and presents the advantage of removable wet lining that guarantee easy maintenance and lower costs.
The Multi Turbo System turbine – MTS – with variable geometry system is electronically controlled thus guaranteeing faster responses, better performance and retaking, in addition to better thermal efficiency. This component also operates as engine brake in the exhaust system. The Exhaust Gas Recirculation system – EGR – is a re-circulator and re-cooler coupled with the block that reutilizes part of the exhaustion emissions which get back to the camera, producing combustion at lower temperatures with less discharge rates.
The new engine brake system of the Dual Power Brake cylinder head – DPB – activates the engine’s cylinder head that is electronically integrated into the turbine. Its advantages are: increasing the operational average speed, the brake force, safety, retaking with fuel reduction, and speed on downward slopes. Presenting less gear shifts, low maintenance costs, and improved brakes and tires service life.
Transmission and clutch
The transmission applied to the new extra-heavy Constellation is the modern ZF 16S 1685 TD with 16 synchronized gears. With excellent variation of gears and high torque capacity (1800 Nm), its aluminum crankcase is 80 kg lighter than the model used so far in the brand’s heavy models. It has an assisted pneumatic coupling system that assures further precision and comfort at gear shifting. The transmission lubricating oil cooler allows bigger changing intervals, since such transmission functions at lower temperatures thus resulting in longer service life.
The Sachs clutch presents a series assembly that facilitates maintenance and interchangeability with the high ton segment: pull type activating bearing, pneumatically assisted hydraulic running, diaphragm type plate with printed case and shock pre-absorbing disc, 430 mm diameter and Sachs 620 C friction material.
Comfortable suspension and strong shafts
On the new Constellation 6X2 models the rear suspension is the rocking arm type that reduces the suspension movement during high torque thus reducing cabin vibrations and improving the driver’s comfort. The 4X2 tractor has series rear suspension with two pneumatic cushions and tensioning springs, double action telescopic shock absorbers and standard Panhard bars – optionally there is the metallic suspension with leaf spring.
The 6X2 counts on Meritor MS 23-185 tractive rear axles with maximum capacity of 60 tons, and series differential transversal blocking system to the VW 25.370 tractor. Such system assures better traction in mudholes, slippery roads or upward slopes. The differential block is activated through a button pressed by the driver on the cabin panel.
A device for partial or total lifting of the third axle allows the Constellation 6X2 vehicles to have also better traction. The Extra Traction Device - ETD – ensures part of the third axle load, during partial lifting, to be transferred to the tractive axle. It is also easily operated by a button on the panel, and assuring maximum traction efficiency on slopes.
The 6X4 models have Meritor MD/MR 25-168 tractive rear axles jointed with the strong and well known Randon rear suspension (bogie type rigid shafts in tandem).
