Hi Friends,
I have 2011 Model years Crafter LWB 120 KW Bjm Engine minibus,
Yesterday, i driving minibus, i see the cluster display glow plug light flashing and limp mode minibus, stopped engine. I start the engine problem fixed 3 minutes later glow plug light flashing and limp mode stopped engine, I goes to bosch diesel service, voach diesel service change fuel filter and road test forblem not fixed, bosch diesel techinician see the my minibus engine, tachnican says "your engine fault fuel pressure sensor", bosch kts computer connect the my minibus, bosch kts see the p1063 fault code. Bosch technican change the VAG 076906051 number fuel pressure sensor. I driving my minibus road test on 30 minutes and problems fixed. One day later i driving minibus i see the cluster display again glow plug light flashing and limp mode stopped engine i goes to bosch diesel service, service computer connct the minibus, bosch kts computer see the P0087 Fault code and technician change the VAG 057130764B number sensor. I driven the minibus road test 30 minutes, problem fixed.
do you have any other idea about these fault codes P1063 and P0087?
Best Regrads.
SM-G610F cihazımdan Tapatalk kullanılarak gönderildi
Best Regrads.
