Vw caddy mirror shells
  • Vw caddy mirror shells
    Hi can any one help in regards to removing mirror shells for colour coding?
    Cheers caddy lack
    Remove 2 screw from the bottom of the mirror - I think they are a T10 Torx bit. Then remove the bottom cover.
    Remove the trim piece from around the mirror. Its just clipped into place.
    Slightly pull out the mirror and its mount whilst pushing the main cover up and towards the front of the van. You may need to insert a plastic trim removal tool at the bottom to help pry it up. Don't use a screwdriver!! You shouldn't have to force it.
    Using Tapatalk
