I hate how VW don't include a fuse layout for your car.
Does anybody have a fuse layout for a MY12 Caddy Maxi Life?
| Closest I could find was a 2008. Hope it helps someone. Position of fuses in fuse holder C, from May 2008 |
| No. | Current Flow Diagram designation | Nominal value | Function/component | Terminal | ||
| 1 | - | SC1 - Fuse 1 on fuse holder C | - | - | - Vacant | - |
| 2 | - | SC2 - Fuse 2 on fuse holder C | - | - | - Vacant | - |
| 3 | - | SC3 - Fuse 3 on fuse holder C | - | - | - Vacant | - |
| 4 | - | SC4 - Fuse 4 on fuse holder C | - | - | - Vacant | - |
| 5 | - | SC5-Fuse 5 on fuse holder C | - | - | - Vacant | - |
| 6 | - | SC6 - Fuse 6 on fuse holder C | - | - | - Vacant | - |
| 7 | - | SC7 - Fuse 7 on fuse holder C | - | - | - Vacant | - |
| 8 | - | SC8 - Fuse 8 on fuse holder C | - | - | - Vacant | - |
| 9 | - | SC9 - Fuse 9 on fuse holder C | 10 A | - - |
T4g - 4-pin connector, black, coupling station for video fuse ¹) T10c - 10-pin connector, electric interface⁴) |
15 |
| 10 | - | SC10 - Fuse 10 on fuse holder C | 5 A | - - - |
J17 - Fuel pump relay²) J533 - Data bus diagnostic interface J623 - Engine control unit |
15 |
| 11 | - | SC11 - Fuse 11 on fuse holder C | 5 A | - | J446 - Parking aid control unit³) | 15 |
| 12 | - | SC12 - Fuse 12 on fuse holder C | 10 A | - - - - |
G41 - Taximeter¹) G511 - Mirror taxi meter¹) T2ac - 2-pin connector, for flashlight charging station, police²) T28a - 28-pin connector²) |
15 |
| 13 | - | SC13 - Fuse 13 on fuse holder C | 5 A | - - - - - - - - - - - - - |
E102 - Headlight range control regulator E132 - Traction control system switch E256 - TCS and ESP button³) E313 - Selector lever⁴) F - Brake light switch J104 - ABS control unit J111 - Brake light relay⁷) J345 - Trailer detector control unit⁵) J500 - Power steering control unit⁶) J587 - Selector lever sensors control unit⁴) J743 - Mechatronics for direct shift gearbox⁴) V48 - Left headlight range control motor V49 - Right headlight range control motor |
15 |
| 14 | - | SC14 - Fuse 14 on fuse holder C | 5 A | - - - - - - |
F4 - Reversing light switch⁷) G70 - Air mass meter²),³) J485 - Auxiliary heater operation relay⁶) N79 - Heater element for crankcase breather¹),²),⁴) N80 - Activated charcoal filter system solenoid valve 1⁴) T16 - 16-pin connector, on left under dash panel, self-diagnosis connection |
15 |
| 15 | - | SC15 - Fuse 15 on fuse holder C | 5 A | - - |
J234 - Airbag control unit K145 - Front passenger side airbag deactivated warning lamp⁵) |
15 |
| 16 | - | SC16 - Fuse 16 on fuse holder C | 5 A | - - - - - - - - |
E16 - Heater/heat output switch⁷) G65 - High-pressure sender⁶) G226 - Oil level and oil temperature sender⁵) J255 - Climatronic control unit⁶) J285 - Control unit in dash panel insert J359 - Low heat output relay⁸) J360 - High heat output relay⁸) Y - Automatic anti-dazzle interior mirror |
15 |
| 17 | - | SC17 - Fuse 17 on fuse holder C | 7,5 A | - - |
F216 - Rear fog light cut-out switch²) M41 - Left tail light and rear fog light bulb³) |
RFL |
| 18 | - | SC18 - Fuse 18 on fuse holder C | 5 A | - - |
J601 - Taxi alarm remote control, control unit¹) T10c - Electric interface⁴) |
30 |
| 19 | - | SC19 - Fuse 19 on fuse holder C | 10 A | - - - - |
G41 - Taximeter¹) G511 - Mirror taxi meter¹) R8 - Two-way radio¹) T10c - Electric interface⁴) |
30 |
| 20 | - | SC20 - Fuse 20 on fuse holder C | 10 A | - | T10c - Electric interface⁴) | 30 |
| 21 | - | SC21 - Fuse 21 on fuse holder C | 10 A | - - - - - - - - - - - |
E1 - Lighting switch E16 - Heater/heat output switch E313 - Selector lever¹) F189 - Tiptronic switch¹) G397 - Rain and light detector sensor⁶) J217 - Automatic gearbox control unit²) J255 - Climatronic control unit⁵) J301 - Air conditioning system control unit⁵) J587 - Selector lever sensors control unit¹) R149 - Remote control receiver for auxiliary coolant heater, behind centre dash panel³) T16 - 16-pin connector, on left under dash panel, self-diagnosis connection |
30 |
| 22 | - | SC22 - Fuse 22 on fuse holder C | 10 A | - - |
J386 - Driver door control unit⁸) J387 - Front passenger door control unit⁸) |
30 |
| 23 | - | SC23 - Fuse 23 on fuse holder C | 10 A | - | T3r - Connector front speed camera⁷) | 30 |
| 24 | - | SC24 - Fuse 24 on fuse holder C | 5 A | - - - |
G273 - Interior monitoring sensor⁶) G384 - Vehicle inclination sender⁶) H12 - Alarm horn⁶),⁷) |
30 |
| 25 | - | SC25 - Fuse 25 on fuse holder C | - | - | - Vacant | - |
| 26 | - | SC26 - Fuse 26 on fuse holder C | 10 A | - | T2ab - Connector on charging station for flashlight³) | 15 |
| 27 | - | SC27 - Fuse 27 on fuse holder C | 20 A | - | J246 - Cut-out relay for air conditioning system magnetic coupling⁵) | 15 |
| 28 | - | SC28 - Fuse 28 on fuse holder C | 5 A | - | E1 - Light switch²) | 75X |
| 28 | - | SC28 - Fuse 28 on fuse holder C | 20 A | - | E18 - Rear fog light switch¹) | 75X |
| 29 | - | SC29 - Fuse 29 on fuse holder C | 15 A | - | V12 - Rear window wiper motor⁴) | 75X |
| 30 | - | SC30 - Fuse 30 on fuse holder C | 25 A | - | E1 - Light switch¹) | 75X |
| 31 | - | SC31 - Fuse 31 on fuse holder C | 5 A | - - - - - |
E16 - Heater/heat output switch⁴) J255 - Climatronic control unit⁵) J301 - Air conditioning system control unit⁵) Z20 - Left washer jet heater element Z21 - Right washer jet heater element |
75X |
| 32 | - | SC32 - Fuse 32 on fuse holder C | 15 A | - | V59 - Windscreen and rear window washer pump | 75X |
| 33 | - | SC33-Fuse 33 on fuse holder C | 40 A | - - - |
E16 - Heater/heat output switch J301 - Air conditioning system control unit J485 - Auxiliary heater operation relay²) |
75X |
| 34 | - | SC34 - Fuse 34 on fuse holder C | - | - | - Vacant | - |
| 35 | - | SC35 - Fuse 35 on fuse holder C | 10 A | - - |
W41 - Fluorescent light right¹) W42 - Fluorescent light left¹) |
30 |
| 36 | - | SC36 - Fuse 36 on fuse holder C | - | - | - Vacant | - |
| 37 | - | SC37 - Fuse 37 on fuse holder C | 15 A | - | M31 - Right headlight dipped beam bulb³) | 56B |
| 38 | - | SC38 - Fuse 38 on fuse holder C | 15 A | - | M29 - Left headlight dipped beam bulb²) | 56B |
| 39 | - | SC39 - Fuse 39 on fuse holder C | 20 A | - | J345 - Trailer coupling control unit¹) | 30 |
| 40 | - | SC40 - Fuse 40 on fuse holder C | 20 A | - | J345 - Trailer coupling control unit¹) | 30 |
| 41 | - | SC41 - Fuse 41 on fuse holder C | 20 A | - | J345 - Trailer coupling control unit¹) | 30 |
| 42 | - | SC42 - Fuse 42 on fuse holder C | 15 A | - | U5 - Front 12 V socket | 30 |
| 42 | - | SC42 - Fuse 42 on fuse holder C | 30A | - - |
U5 - Front 12 V socket U18 - 12 V socket 2, on left in luggage compartment |
30 |
| 43 | - | SC43 - Fuse 43 on fuse holder C | 15 A | - - |
J17 - Fuel pump relay⁵),⁶) J49 - Electric fuel pump 2 relay⁶) |
30 |
| 44 | - | SC44 - Fuse 44 on fuse holder C | 40 A | - | J126 - Fresh air blower control unit⁴) | - |
| 45 | - | SC45 - Fuse 45 on fuse holder C | 20 A | - - |
J39 - Headlight washer system relay³) V11 - Headlight washer system pump³) |
30 |
| 46 | - | SC46 - Fuse 46 on fuse holder C | 7,5 A | - | J519-Onboard power supply control unit | 30 |
| 47 | - | SC47 - Fuse 47 on fuse holder C | 25 A | - | U1-Cigarette lighter | 30 |
| 48 | - | SC48 - Fuse 48 on fuse holder C | 30 A | - | J774 - Heated front seats control unit¹) | 30 |
| 49 | - | SC49 - Fuse 49 on fuse holder C | 10 A | - | J386 - Driver door control unit²) J387 - Front passenger door control unit²) |
30 |
| 50 | - | SC50 - Fuse 50 on fuse holder C | 25 A | - | J393 - Convenience system central control unit | 30 |
| 51 | - | SC51 - Fuse 51 on fuse holder C | 30 A | - | T10ai - Connector coupling point special signals³) | 30 |
| 52 | - | SC52 - Fuse 52 on fuse holder C | 25 A | - | J13 - Fresh air blower relay²) J519-Onboard power supply control unit Z1 - Heated rear window |
30 |
| 53 | - | SC53 - Fuse 53 on fuse holder C | - | - | - Vacant | - |
| 54 | - | SC54 - Fuse 54 on fuse holder C | - | - | - Vacant | - |
| 55 | - | SC55 - Fuse 55 on fuse holder C | - | - | - Vacant | - |
| 56 | - | SC56 - Fuse 56 on fuse holder C | - | - | - Vacant | - |
| 57 | - | SC57-Fuse 57 on fuse holder C | 5 A | - | J754 - Accident data memory³) T10c - Electric interface⁴) |
58d |
| 58 | - | SC58 - Fuse 58 on fuse holder C | 10 A | - | T4g - Video fuse³) | 30 |
30 |
