I can't find a discussion on this so here goes.
My Caddy comes with what is variously described in Google searches as a "split angle" or "Euro style" driver's door mirror.
There is a vertical dashed line about 25 mm in from the outboard edge and that part of the mirror is at a different angle to the rest of the mirror. Logic tells me that this should be telling me what is further outboard from the outboard edge of the mirror, however the image says otherwise.
When driving and I can see the right side road edge marking, when the line ends up in the change in angle on the outside edge, the edge marking bends towards the back of the car. If I were to move the mirror outwards, the line in the normal part bends away which is what I would expect the image in the outside edge to do. I have an overtaking wedge mirror on the inside edge of the mirror and as I expect, it bends the line away from the car.
Where can I find information on this feature? The manual does not cover it, and at first I thought it was a flaw or some transport protector that was left behind. I have since seen some photographs taken but none showing a line parallel to the direction of travel and so can't be sure as to what this does.
If it works as I would think it should, it is very useful, however I would hate it to be the other way
