Gear shifter refitting?
  • Gear shifter refitting?
    Hi all, have just fitted RNS510 and bluetooth to my caddy, I pulled off the (DSG) gear shifter to remove the front of the centre console, and now when I have put the gear shifter back on, the button is stuck all the way in, it will not come out when I put it back on the stick and thus it won't come out of park unless I take the shifter off and pull the green shaft up, then it works..... I suspect I may have broken something when taking it off, but there does not seem to be anything broken.
    ???? HELP!!!!
    thanks
    Matthew
    2010 MY10.5 R36 Wagon, Biscay Blue, RNS510, Dynaudio, Sunroof, towbar, Dynamic Chassis Control, No lazy back door
    2008 Audi Q7 4.2TDI, Radar Cruise, Lane Assist, Blind Spot Assist, Heated Seats Front & Rear, Alcantara Hood Lining, Wooden Gear knob, Nappa Leather, Plus all the usual V8TDI gear, like 760nm of Torque!
    hi mate
    from memory when i last time did you have to pull silver button to max (dont brake it) hold in that position and slide down all the way..it should lock up by itself ..
    Oli
      How much did the RNS510 set you back?
      Been looking into aftermarket options for Satnav & Bluetooth which can be done fairly cheaply, but would prefer to stick to VW genuine stuff if the price is right
      Also wouldn't mind putting a reverse camera on as well... Park sensors that were sitting locally by the dealer are rubbish & they aren't exactly keen to do anything about it
