Hey guys.
I did the inlet flush that Andrew has been raving on about to me for a couple of months now..
Definitely worth it if your Caddy has done over 50k. Mine's done 65 and the difference it made was impressive.
It's smoother on trailing throttle (very light throttle), more responsive and pulls harder too. It also seems to come on boost more smoothly. I'm pretty happy with the result.
Here's what i did.
I pulled the pressure side intercooler hose off and sprayed the stuff in with the engine idling. This worked OK but if i wasn't careful it dribbled back out.
I ended up slipping the hose back over, jamming the nozzle under it and into the inlet. Then i grabbed a rag and sealed it off so it couldn't blow back out. Squirting it in, in increments as the engine didn't really like it too much and idled pretty rough if you squirted it in too fast (i actually caused it to stall at one point!).
All in all i'd definitely recommend it. Go see your mechanic if you don't like doing these things yourself and ask them about it. Not sure what it's worth as the old man have a couple of boxes full of the stuff he got from a retiring Wynns rep.
Here's what i did.
 Caddy TDI inlet clean
