Hi there,
I've had my clutch & pressure plate replaced and the flywheel machined. Since then, gears grate and the cable adjustment doesn't help. After repeated unsuccessful attempt by the repairer (U*******e) to fix the the problem, my hubby spat the dummy and removed the g'box. We were told by a VW mechanic that the flywheel (single piece one) has two faces, one for the pressure plate to mount on, and a recessed face for the clutch plate, but he did not know what the recess measurement was. We've tried unsuccessfully to obtain this spec from (a) the repairer, (b) both VW agents in Brisbane and (c) VW Australia. Nobody cares!!!!
I'm told the specification is 13.4 mm, I have 0.5 mm i.e almost flat across the clutch side of the flywheel. However the machinist still maintains that the flywheel was machined "to spec", but the clutch won't release and the gears grate.
Anybody? I'm desperate to get this car back on the road, it's done less than 100 km since last August when the repair was done.
Pic of the problem attached
