2001 Polo cold start issues
  • 2001 Polo cold start issues
    On cold start there is a strong smell of fuel, the idle is choppy and sometimes the idle will hunt before the car stalls. It will restart without trouble.
    When the car has warmed up there is no petrol smell, and the idle is normal, no issues at all.
    Does this car have a cold start injector? It is an AHW engine.
    No cold start injector. Ahw is twin cam. 16 v which has 4 injectors. You may have a bad coolant temp sensor. It normally gives bad hot start but some can read big negative figures and it drowns itself . The hunt may be it clearing after that. Also might have a problem with throttle body , might not be setting for cold start and fast idle which might be choking it.
    Jmac
    Alba European
      Thanks Jmac. I've ordered a new temp sensor to see how that goes. With the problem seemingly a cold start issue only, it should be right to drive while I wait for the sensor.
        Like i say mate its a major culprit when hot but have def seen it when cold . Well worth a try and then to the others above mentioned
        See how you go, fee free to pm too mate
        Jmac
        Alba European
          Jmac
          Cheers, Jmac.
