Alright feeling good about going 75W90 if you've had no shifting dramas. Yeah the shifter cable reset was a revelation first time I did it. This arvo I received the ECS bellhousing scraping tool for the 02J bellhousing on our gearbox. That was gifted to me courtesy of Seb from eurorevolution so big thanks for that on short notice. I also got solid bushes from there for the cable/shifter bracket mount onto the gearbox which should improve thing further. Can't wait to get this thing in!
Sam's build thread
Originally posted by sambb View Postedit. sorry not a disco potato Gt2860 its a Gt2871 with the 0.64 exhaust housing. From what I can see there are hardware kits galore to run this turbo. I'd be interested but would want to hear from anyone who's run it on our engine in that guise to get a gauge on spool times, peak boost rpms etc cos despite being ball bearing turbos's I've read in a few places that they are not particularly quick spoolers.
The GT2860 has been on cars since the MK4 gti came out im guessing so its a tried and tested package tho im sure most are going towards say a GTX2867 these days.
If you look at something like a GTX im guessing spool would be slower than a K03 but probably easier to drive as a K03 is like on and off, has nothing then everything and not progressive as a bigger turbo.
Im in the process of finishing up my GT2860 but worried that it is too small
Oh in regards to the LSD not sure if this can be used but i have heard of some people adding it to plate type LSD's
Thanks mate. Ends up I was actually given two turbos. One is Garret T28 off a GtiR Pulsar and the other is a GT2871 - the good one that has an Inconel turbine and a high nickel exhaust housing. I know that a Gt2871 is not considered to be a big turbo as such. If I was circuit tracking a car it'd probably be spot on. For what I do though I need a faster spooler than that - definitely not interested in a big turbo. My mech is a big fan of the new borg warners. He's was primarily a Nissan/Sr20/Garret man but has well and truly jumped over to borg warner for their EFR series of turbos. He's trying to encourage me to get one of those for their faster spool, flat torque delivery, the way that you can clock them to any position you need, their nice smooth wastegate ports etc etc vs the garrets. It isn't going to happen though as money is getting low.
So I've swapped him the two turbos for a garrett GT2554 which is more in line with what I need. He assured me that for what I do I'd be falling into lag holes everywhere with the next sizes up from that. Now I've just got to look at whether I could retain my standard ported exhaust manifold and run an adapter plate ie a down mount garret, or go with all those US kits and a higher flowing up mount. And also fundamentally I need to look at where it fits against the K04 options too. All very long term though. Cant beat a free Garrett though really to get you started down a path though.
edit: ive attached a couple of pics of one of these borg warner EFR's on a custom 4 into 1 equal length manifold that he built. Its an early little merc slk with the 2.3L 4 pot that was factory supercharged.Last edited by sambb; 22-06-2017, 07:08 PM.
Alright so the rebuilt box complete with a wavetrac diff is finally in. Not going to lie it is a pretty mammoth task when you're doing it by yourself lying on your back under the car. No step is particularly hard its just that there are many many many steps from start to finish. I've now dropped 2 gearboxes and fitted one so if I ever have to do it again it'd be quicker, but to be honest if I was forced to do it myself again I'd probably just hoick the whole engine and gearbox out the front and do it that way. It'd be much easier that way I reckon.
It is just so dam hard manoeuvering the box in when its just sitting on a jack and whenever you feel close to getting it past the crossmember the angles have it nearly falling off the jack. I ended up dropping the coolant and taking off the bottom radiator hard fitting so I could clear that hose. Also lucky I still had an OEM engine mount on the drivers side and could put some pretty extreme angles on the motor to help. It was then lots of motor up, gearbox up, twist gearbox, lower motor again, raise gearbox etc etc do that a hundred times and you'll have it in - or at least that was my experience. You just have to be patient. I don't know how the guys that have done the bigger 6 speeds got them in.
The first 3 pics are of a bit of an issue with the forge TIP. The heater pipe absolutely wedges it squeezing it closed a bit just past the bend. If you look closely in the pics you can undo the bolt holding it to the block, pull the pipe out a little and refit with a spacer (I used a nut). That way the pipe doesn't crush the TIP. Worth doing cos as you can see in the pics it was really closing it up. Last pic is of the result afterwards.
So basically the car now has a rebuilt box with pinion brace, wavetrac diff, is single mass flywheel converted with ECS 14lb steel billet flywheel, Stage 1 ECS clutch/pressure plate, my vibratechnics east/west engine mounts in, shifter bracket is solid bush mounted to the gearbox, forge quick shift is on and a new rear main seal. Only thing I didn't do which i'll get to is changing out the rubber shift cable bushes for 42DD solid ones too.
There was a big hiccup though. The seriously only thing I didn't have a torque spec for was the driveshaft/hub nut. I torqued it up at home and then went down to my mechanic/engineer mates to give his 3/4 drive wrench back. After driving it a bit I thought I'll just check the torque again in case the wheel bearing has freed up. So when I went to check it it was looser so I went to nip it a little further to where it had been and it got looser not tighter. Luckily the nut did come out and it look stripped. Lucky break I thought as it didn't lopok like the driveshaft threads had let go. I had another nut on hand but when I went to thread it on it wouldn't even go on. Looking at the first nut it wasn't stripped at all. Its threads were full of stripped driveshaft thread. To say I felt like my guts were going to drop on the ground is an understatement. I'd just massacred a perfectly good driveshaft and now was going to have to do that job all over again. I was stranded at the mechanics (you cant drive without the hub nut torque or the wheel bearing will fall to pieces) so I had to walk home. Luckily a mate came to the rescue and lent me his road reg track car to get around in and by 6pm that night I had my spare driveshaft rebooted and another set driveshaft to gearbox flange bolts, seal and hub nut on order. $160 bucks later and a mornings work today and its all fluffy again but Jeez. Moral of the story is just because most cars take a lot more hub nut torque and everyone says she'll be right go nuts ALWAYS get the torque specs for everything. As it is the spec is 50Nm which is nothing with a 3/4 drive wrench then a further 45 degrees.
So I cant really give a review of the diff yet. I have a club level hillclimb on Sunday at Ringwood/Raymond terrace and have to bed the flywheel/clutch in properly with as many normal street kays as I can before I go nuts on it. So its been very pedestrian so far and will be until the light goes green on the line on Sunday. I can give some diff feedback then.
As far as the single mass conversion goes wityh the lighter 14lb flywheel it is smooth as you like, not prone to dying as you get off the clutch pedal at traffic speeds, doesn't vibrate, and does seem to rev up a little quicker. The stage 1 clutch - time will tell how that goes. Provided I let it bed in nicely (the hilllcimb on sunday is all second gear so only one full noise gear change) I think it'll be ok. The only thing is that the stage 1 pressure plate is very light - lighter than the stock dual mass. I've never ever been a fan of light clutches and have always preferred to have to need to use a bit of force through the bite point but it is light. I only hope that once the clutch gets a bit more bitey at the friction point once everything beds in that there will be a bit more feel through the pedal. I have also been driving my mates clio with a stage 3 race clutch which is cable too so it could just be that which is skewing how I assess it, but you get used to anything so its no biggy.
anyway that's that. 2 nights of work from kids bed time till 4am plus a morning to have all of the above done. (then another morning to fix my driveshaft f***k up). Feels bloody good though so can't wait to hit the track this weekend!Last edited by sambb; 23-06-2017, 01:48 AM.
do you mean the manifold in the pics in post#79? If you mean that manifold that's for a Merc SLK 2.3. I'd just included those pics as eye candy cos I'd been talking in that post about the new Borg warner turbos that a mechanic mate of mine has been running instead of the Garretts he'd previously always gone with. Its not a VAG 1.8T 20V manifold - his custom job I believe.
The car does feel entirely different in tight stuff with the diff. I haven't gotten anywhere near really pushing it but I'd describe needing slightly less steering lock on than you'd have had with the single spinner. It feels like you have less tyre slip angle and the sensation that the inside wheel is pulling the inside front to the inside of the corner. I won't do it till I see how it goes at the track but I'm betting i'll be able to take the front bar up to the hard setting and i'll still have way better drive than before. Its seamless too. Nothing abrupt about it. It might be raining on sunday morning and I doubt above 10 degrees for the first runs at Ringwood so that'll be a good test on cold semi's for the diff. can't wait!
Aaaah. I was tired and unable to read the post!
They are a massive improvement in corners. I never tracked mine, but difference through roundabouts was unreal.
There's a Cars and Coffee thing on at a VW workshop on the Sunday too.
But probably unable to make it with Ringwood start times
You're a machine Sam, congrats on getting it built so quickly.
Yeah the wavetrac is a nice treat. Will probably be more impressive in hill climb/motorkhana than track events where 2nd gear is so widely used. I found my diff was more impressive with front sway bar disconnected as it allowed for wheel travel and perhaps better loading of the diff. I'd have thought that'd be the way to go for your preferred events.
I've got my first track day since last November tomorrow. Champing at the bit to get out. I've still got those A050 softs to wrapped up and yet to run, though am thinking of selling them and just getting a performance street tyre.Track Car: 06 Polo GTI Red Devil mkII
Daily: 2010 VW Jetta Highline
Oh yeah I forgot you live up that way HaydEn. Do you know where it is? Its north of the heatherbrae round about and then you turn down Italia rd. There's a motorcross track up that rd too. If you head up that rd though you'll hear the cars running. If you make it come and say Hi.
Yeah I'll basically start with my normal setup suspension wise and just take it from there. I'm guessing having the diff now is going to force a few changes though, but we'll see. Like you say I think a softer front should work best especially if its going to be wet in the morning like they say. I wonder if I'm still going to be able to really go for it - after all the hard work i'll probably be so scared of bining it that i'll be slower than normal! Whats the go with the Yoko's? are you worried they'll be too soft. I was told by a Toyo rep down here that the A050's are overall a very soft compound and that an A050 medium was nearly the same as an R888 soft. If you are going to sell them don't let them sit too long. You'll get top dollar while they are still virginal sticky marshmallows.
Agreed Its the best feeling isn't it, knowing you'll be on track the next day. I love the whole ritual of getting everything squared away, who'll take what and getting it all packed the night before. What I don't like is the early cold starts up the freeway after a sleepless night cos I can't sleep like a little kid.
Last night I swapped my longer gear stick back to standard. Sheez the forge quickshift set to its shortest on a standard gear knob is very clicky isn't it. Not used to it but I found it nearly undriveable. Will either have to lengthen the throw on the quickshift pivot or go back to the longer stick. One thing I haven't even looked at is proper logs. The engine hasn't come in for much attention with everything else happening. I noticed on the gauge the other day that it boosted up to 1.5 bar! My modded turbo never did that probably because the wastegate was getting rid of the excess more efficiently. So last night I checked the wastegate actuator preload and backed it off to 2.5-3mm preload. A few bursts on the way home last night and it was peaking at 1.35-1.4 bar which is probably better, so tonight i'll log it and see if anymore timing can go into it and then I should be good to go. Its going to be weird sitting on the line and not having to fiddle with SMIC fans and water sprays - hopefully the FMIC will keep things cool as a cucumber.
Re the tyres, At the moment I'm not so inclined to run for a lap time, but out to enjoy myself. With such sticky and soft tyres, I couldn't just go hard for 5 laps, would have to be more strategic in my approach. I'm curious as to what the car could do on these tyres tho...
I expect tomorrow will be my last outing on the Kumho V70's.
Re your logs, be sure to check EGT, intake temps, AFR/Lamba too.Track Car: 06 Polo GTI Red Devil mkII
yep will do. I'll basically just check the logs from a health point of view. I'll probably only find the time to add timing if its crying out for it. Can't do too many power runs around here. So many bloody fit people out walking dogs etc even in the industrial estates. Always too many civilians around.
Yeah those kumhos were pretty shagged. Whats the go then - medium compound R specs from the harder brands or a street semi like AD08R's. A few guys run Nitto NT01's. They are street legal but have massive tread blocks and are cheap for what they are.
Well I ran at the Ringwood motorsport complex at club hillclimb on Sunday. It was a track I hadn't done before where you head up the hill and go across the top but instead of coming straight down do a second loop of the top again. We got 5 runs despite 3 nasty incidents so due to the extra length managed to get some good seat time to re learn the car.
It was dry but very cold. It was about 10 degrees for a good chunk of the day and when it did warm up the sun went behind the trees which froze the track off again. My day went from just wanting an outing in my own headspace, to a really close competition with a Renault Megane RS275 trophy -R lightweight (yep the one with the stripped out interior, factory cage, torsen diff, ohlins, akropovic exhaust, brembos + it had a dump and a tune on top of that) and a new ford focus RS (the drift mode one). The Renault was the only other car in my class as I'd been bumped up into the next type 2 category of over 2 litre due to my mods.
I used to get 5.30s first splits which is the equivalent of our up hill round a bend 20 ft time but I managed a 4.40s on the day so the car was 7/10th quicker in the first 20 feet. In the last state round at this spot I was beaten to first position in my class by 4/100th last year so to gain 7/10th or so with the LSD just on the line is massive. And there's more in it on the launch too eg Normally I load the car up on the handbrake with the clutch on the friction point to get the turbo primed but I wasn't doing that as the clutch had only just gone in. I was just side stepping the clutch at 2500 and more often than not getting too much wheelspin.
The limi was a revelation. Previously because I could never get the power down on exit I used to have to trail brake right deep to the apex before feeding the power in. Now I was getting on the loud pedal early and I couldn't believe how if I got my timing right I could bury the throttle and still steer through the remainder of the corner at full noise. Even on my 1st run where due to the track configuration I could get two looks at the same corner I was able to get on the power way earlier than the first time through, it just gave me that much confidence. Unbelievably at the end of the 1st run I was sitting in 4th overall!
On my next couple of runs I concentrated on trying to find the limits of just how early I could get on the throttle (and did) and made a couple of mistakes including clipping a cone and getting a 5 second penalty but that was ok for this kind of event because I just wanted to learn the car for when we come back here for the state event in August. I hadn't really noticed though until someone told me that I was locked equal tenth with the Megane both of us on the exact same time of 60.66 and the RS focus was behind us.
That was when it became like Ok I could get a top ten here and have a shot at beating the Megane that I took it a bit more seriously. But in the afternoon the track started to go away. The Focus RS started to get quicker as the grip diminished and eventually topped both of us. On the last run the Megane got me by 6/100ths! ouch. He admitted to me that he'd dropped a lot of tyre pressure, softened off his ohlins and went and parked his car in the sun to keep his tyres warm (local tricks eh!). I'd taken my spacers off the rear to try to get the rear a bit more slidey and dropped air off the front tyres and although I went as fast as I think I could have gone it wasn't enough.
All up it was a really fun day. The car was bloody quick with the diff. Considering that I was down slightly on power since the standard K03s is still in the car I'm very happy. Its pretty cool when every time you walk back to the car there's someone sniffing around it and looking a bit disbelieving when you say that it wouldn't have more than 230hp and only has strut suspension. There's always more improvement in me that's for sure but for the first time in a long time there's now lots of time in the car. Awesome under rated little cars these are.
Things to do before the next rounds:
- I have to make a decision on which way to go with the turbo. At minimum I need to get my ported exhaust and ported K03s back in the car but that will necessitate a new turbo core $650. That has me seriously considering not much more outlay for a turbo upgrade but I'm still not sure there's much more time around the bulk of the hillclimb circuits on the calender in a bigger turbo other than say at Huntley or Panorama. By the same token I can always rebuild my K03s and sell it later with the other standard K03s to finance that upgrade.
- I'm now wondering if the remainder of my kitty is better spent on coilovers. Strut suspension more or less tops out at 200lb/in which I can't go beyond unless I go to coilovers. And while I can get a lot of roll stiffness from bars etc it still doesn't stop the car nose diving under brakes and lifting under power. So MCA's or something with at least some rebound adjustment might be on the cards.
- because of my driveshaft mishap I ran out of time to get a proper alignment before the event. I could only manage a toe n' go. My camber was -1/1/2 degrees on the left and -2/1/4 on the right and slightly more castor on the left. So I'll address that. Hopefully my modded rear beam will be ready too so I can chuck that in and do the brake fluid and some remsa front pads at the same time.
all up I'm very happy though.
sam
Ive been sent the pdf provisional results but can't work out how to post that up here. I took some pics of the active timing screens and results so I'll get them up tonight. When the results go online I'll put them up here and in the tracking threadLast edited by sambb; 26-06-2017, 08:44 AM.
here's the only vid anyone has posted of the event which shows the track config we ran. Its shot from an US legends car that's been converted to Aussie legends spec. He was 1.5 secs quicker than me so really moving but it gives you an idea of how tight and technical this track is.
That's awesome to hear you went so well. That's a hairy little circuit, not much room between track and tree. Is it mostly 2nd and 3rd gear I'm guessing?Track Car: 06 Polo GTI Red Devil mkII
