Originally posted by sambb
View Post
1. High restriction on the exhaust side of the engine, too small an exhaust turbine/housing, too small exhaust valves/ports and/or manifold.
2. Too much boost for the compressor to produce efficiently (ie; out of its efficiency range).
3. This results in too high compressor outlet air temps.
4. Too small an intercooler to control the compressor outlet air temps.
5. High restriction on the inlet side of the engine, too small inlet valves/ports and/or manifold, pipework, throttle body etc.
6. Excessively retarded ignition timing made necessary by too high combustion pressures and/or too low an octane fuel.
7. It's a spiral effect, # 1 means you need more of #2, #5 means you need more of #2, more of #2 means you need more of #6 etc.
Without changing anything else you could lower the EGT dramatically by switching to E85, as it reduces the inlet air temps, lowers the combustion temperature and facilitates more ignition advance.
Gary
