Well where do I start. First of all, got a stage 1 code from Gavin Custom Code a few months ago. Car pulls well enough when the boost works.
So this morning (months after the ECU flash) I quickly installed a boost gauge. Started the car from cold, warmed it up to find that it boosts to 17psi dropping off to 15psi as it gets closer to the redline (stock turbo running out of puff for the engine me thinks).
Now the inherent problem I have had since day 1 I think.
If I drive the car for a period of time say greater than 10 minutes and park up for a while, say again greater than 10 mins. The car has no power after this. So today with the boost gauge I confirmed that this is the case with a lowly 4psi of boost (limp home mode equivalent).
Now when I first got the car there was a fault code on it relating to the N75 and the garage said that it was boosting to 9psi after resetting it (stock tune).
Right, so potentially faulty N75.
From there I disconnected the top hose (take the N75 out of the equation) and boosted to 17psi. I did quite a few 3rd and 4th gears runs getting braver to see where the boost would build to and never ever went over 17psi. Even with pretty hard presses on the accelerator for 5 seconds or more.
So first things first, would I be right in saying that the N75 is sticking or possibly going out of resistance spec when heat soaked with the car stopped.
Secondly, I think I must have something in the boost circuit limiting boost pressure as it never spiked above 17psi with the N75 disconnected.
Now, to take the N75 (delete) out of the circuit is it the right thing to just install a manual boost controller and set the relief to say 18psi for example and the ECU tune / remap will take care of everything else as long as I keep the N75 connected to the wiring harness.
