Big Brake Kit
  • Big Brake Kit
    Hey all,
    Im running the ecs stage 3 bbk on my car. Have had the kit installed for a while and from day one I've always been unhappy with the pedal feel. Have to double tap to get a proper feel. Im looking into upgrade everything else around the calipers, so am looking into brake master/booster and braided lines. I do remember reading somewhere that an mk4 r32 setup might solve the issue, no clue though. Would anyone be able to shed any light on this?
    Thanks in advance
    Sent from my SM-N920I using Tapatalk
    what size is the kit ?
    I have a full R32 brake set up for sale for $300 .
      Think they are like 332mm up front. I had a R32 setup that I got ride of because I bought these. Brakes are fine, I'm just hopping to rectify the master/booster, lines so i can get a better pedal feel
        I had the S3/TT brakes all round on my car, and could never get a good pedal. It didn't make sense - OEM parts should have been fine. I once, years on, used a hand-pump style of pressure bleeder. Amazing. Why didn't I do it earlier... It was such a small amount of air in the fronts
        Just a thought!
          Just a thought!
          I've used both manual bleeder and a compressor bleeder, cant get a good feel, still feels like there's some air in there
            Hoyhoy.
            Could be the firewall flex, standard the wall moves about 5mm.
            What I done made all the difference.
            To Improve Me Polo. - Page 9
            Hooroo.
              Originally posted by Eddy View Post
              Hoyhoy.
              Thanks for the reply! That looks interesting. Have you got a picture of it mounted in the engine bay? I never actually thought about firewall flex; thats a good point
                Hoyhoy.
                I just checked & no, but give me a couple of days & I'll see what I can come up with.
                Hooroo.
                  Yes it's quite common mod in the Subaru world with off-the-shelf aftermarket parts available: https://www.mrtperformance.com.au/br...3d-139405.html
                  - Tigger73's 125TSI Build
                    Hoyhoy.
                    I looked @ getting some pics, but ya can hardly see it when installed, sorry.
                    Hooroo.
                      Hoyhoy.
                      Not a problem man, thank you anyways!
                        My suspension bloke did some research and came up with the option of swapping to a passat brake master cylinder. Polo is 20mm vs 22mm for the passat. Will keep this posted as to how that goes
                          Interested in this
                          MODS- TOO MANY
                            If it's doable that'll be a great upgrade over our MS
                            06 Polo TDi
                              They have found a brake master to suit that is bigger. Oem vw item. Will have to wait till it arrives to take a few photos and get some part numbers
