panels/paint/polish  have never been something I've turned my hand to so looking for some advice.
Can the exterior door bump strips be removed without both mangling the door and strip? if so, whats the best approach for the removal?
Also has anyone had to remove the straight exterior window seal/strip running along the top edge of the door ie where you rest your driving arm when the window is down?
I've got scratches from bushes I came a little to close too down each side of the car and one of the trims is gouged. Scratches should polish out so just wondering if I'd replace the trims in the process or just leave them off altogether if the door will look unmolested underneath where the bump strips are once they are removed.
thanks for any help
sam
thanks for any help
sam
