I have a problem my cup holder wont close.. how does it come out ? anyone know.
the rattings is giving me the ****s
I've noticed that everyone in the passenger seat that tries to close it almost breaks it. I've never had a problem closing it in the drivers seat. Sounds crazy, if it still doesn't work then take it back to the dealer.
push the white button on the bottom right (just behind the panel that's supposed to sit flush with the dash). Should pop out ready to be pushed in again.
Glad I found this thread. My cup holder won't open. Ben, if you're reading this, I remember just touching yours and 'voila!', it opened. Mine seems stuck. Manual says theres this white button, for the life of me, I can't even see it!
it's tricky- the outer flaps go on the inside, and the inner flaps go outside of the outer flaps.
just as long as when you're closing it, you ensure that you push the outer flaps toward the inner flaps and get both outer flaps on the inside of the inner flaps/ conversely, when the outer flaps approach the inner flaps, get the inner flaps to go on the outside of the outer flaps which go in between the inner flaps, then you'll be right.
get a small flat head screwdriver and put it on the right hand side of the black part of the cupholder inside the dash and push the handle towards the cd player... should sorta pop out..?
9n3 Polo GTI - | GIAC | APR R1 DV | RDA slotted rotors | Remsa pads | Whiteline bushes | 17x7.5" RS6 reps | Optima yellow top | Clarion / Audison / AVI / peerless audio
