1 of 2
2 of 2
Polo 9n3 Performance Tracking Thread #2
Winton long track - 1:46.9 - Result
Edit - found you! Result addedLast edited by kaanage; 27-05-2018, 09:56 PM.Resident grumpy old fart
Originally posted by sambb View Post26/5/18
SMSP "Amaroo" south circuit
I've added Sean as well but were any of the other 3 Polos there 9N3s?Resident grumpy old fart
You can delete the results post, Sam.
I was just saying not to bother posting links for Natsoft results.
The circuit and date are what I use to confirm.Last edited by kaanage; 28-05-2018, 12:50 PM.Resident grumpy old fart
Nice result Sam!
I may as well put down my dyno figure seeing as this thread has those on here too.
273fwkw/366whp - dyno is a dynodynamics.
Polo is actually going back to the dyno for some tweaks such as boost by gear and to wind it up a little bit further with the addition of a 4 Bar fuel reg so that number will likely increase a bit2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
Thanks for adding me for Amaroo.
Specs: Stage 3 (K04), LSD, Federal RSRRTrack Car: 06 Polo GTI Red Devil mkII
Daily: 2010 VW Jetta Highline
Originally posted by kaanage View PostCan you give me the date for this, Simon? Natsoft don't allow persistent links for results anymore and I couldn't find you in the results for the trackdays on the 12th nor 13th.
Natsoft race results
Track: Logic Centre Wodonga
Date: 8/4/2018
Event: 1
Entry number: 99 - Simon Kerr
Best Time: 1:04.4379
yeah?
That would make things super easy [emoji2]Last edited by kaanage; 20-08-2018, 12:42 PM.Resident grumpy old fart
Yup 4th Gear and standard ratio's. Will be interesting to see what it makes with the additional flow, could crack the 285-300fwkw range maybe.
Sam, it holds its own pretty well but looses a lot of ground due to traction loss through 2nd so I'm always playing catch up. Once I have finished the suspension mods and boost by gear I think it will be pretty well planted... maybe2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
Sorry for not putting up your dyno figures earlier, Louis.
You're now on the board (at the very top) and I've linked to your build specsResident grumpy old fart
