Hi team, before it's suggested, I HAVE tried the search function.
When starting the car in the morning it sounds like a large vacuum cleaner going under the bonnet; from research it seems highly probable that it is the SAI system. Other than sounding like a Hoover, is there a chance that it is also causing performance issues?
By unplugging it, there will be warnings, and flashing lights, possibly a limp mode; unless there are resistors in situ.
If the ECU is coded to not look for the sensors, could the SAI system remain, physically, in place without causing any further issues; or will it mean that boost could be lost?
TIA.
TIA.
