G-8VXWWTRHPN Loud Knocking sound when going on bumps. Control Arm Bushes Worn out? - VWWatercooled Australia
  • #16
    Nolathane do a pair for $80. Bon giornos in ozzy park can supply and fit
    • #17
      Thanks mate. I will give them two a call tmr. About how much will it cost in labour do you know? Would you be interested in installing them ? XD
      • #18
        Originally posted by Amaze View Post
        Thank you Brad! You are amazing!
        Just really good at internet searches between running database queries
        • #19
          Not sure how different time-wise between your Pog & my Tig, but my mechanic just did mine for 1 hour labour charge (110). I supplied the Whiteline ones (105 posted).
          • #20
            I'd have thought up to a couple of hours. The labour will far exceed the price of the mounts. But it'll feel better than new once done.
            Daily: 2010 VW Jetta Highline
            • #21
              Yes you're probably right ... Mine was up on the hoist already having other work done so that would have cut some of the time component down...
              • #22
                Thanks for all the help guys! Another question though.
                Is it common practice to replace the 6 bolts on the Balljoints (Part No: N10127707) and 2 bolts on the front wishbone bush (Part No: N10141801) with new ones when refitting the wishbone?
                Leon
                • #23
                  Leon
                  If you were being particular, you would do the front bolts. You should disconnect the ball joint from the hub, 18mm spanner, if the alignment was good before the bushes fell apart. It should be really close again, once you fit the new bushes.
                  Disturbing the ball joints on the wishbone will need an alignment for sure.
