Hi all,
For those that are interested in what the actual spring rates are of the springs in commonly available spring kits versus stock, here is a bit of info:
Stock OEM - measured in a spring press
front - 26.6N/mm = 152lb/in (green green orange orange orange) - in eibach sydneys spring press.
rear - 25 N/mm (*5.710) = 142 lb/in (orange - white - white - orange)
H&R 30/35 drop spring kit 29333-3 (by email to germany)
front - 27 N/mm
rear - 27 N/mm
Eibach 20/15mm drop Pro Kit (by email)
front - 27 N/mm
rear - 23.5 N/mm
Weitec ( green springs) - measured in a spring press
front - 27.5 N/mm = 2.80 Kg/mm = 157 lb/in (#VW582VA/000)
rear - 22.5 N/mm = 2.29 Kg/mm = 129lb/in (#VW582HA/000)
ST by KW 20/15mm drop spring kit (#28280075) - by email to KW germany
front - 27 N/mm
rear - 22.5N/mm
anyway...food for thought for you all
sam
front - 27 N/mm
rear - 27 N/mm
front - 27 N/mm
rear - 23.5 N/mm
front - 27 N/mm
rear - 22.5N/mm
sam
