Pod in a box R&D
  • #31
    So how are these going on the 1.9 diesels? Am I right in assuming your using them on the diesel polos?
    • #32
      Sorry, no one I know has tried it on a TDI, to my knowledge.
      • #33
        Oh, one of the comments earlier made me wonder.. Shame I'd be curious for the results.
        Good work on the products though mate.
        • #34
          Are you still doing these Gav? If so I'd be keen on picking one up.
          • #35
            Same here as well Gav.
            Sent from my D6653 using Tapatalk
            • #36
              I haven't made one in a while but I do have the bend hanging around and a lightly used Unifilter in the boot of my GTI I could knock one up. But don't hold your breath. I just moved to Melbourne and I am busy setting up a wokshop.
              Although I might need to make one to get the Squib through a RWC here.
              It's not so hard to do if you're a little handy.
              • #37
                Thanks for the reply Gav. Had a closer look at the photos, doesn't look too hard. Might give it a go myself. The bend and unifilter look like I will be able to pick them up off the shelf? Is there any other modification required?
                • #38
                  The bend is different sized at each end (mine was). Can get it off eBay.
                  • #39
                    Got it sorted. Supercheap had a silicone hose with the perfect size on each end. Filter is one that I used to run in my 2.6L B5 A4. Was a tight squeeze but I got it in.
