A dull question about the fan
  • A dull question about the fan
    Right. The air cons not on and the fan is on zero. But everytime I stop at the same lights after travelling slowly up Military road and then come onto the freeway at speed the fan goes warm and the car almost smells a bit like burning...
    I've checked the engine temp and its exactly in the middle each time so that ain't it......Is this normal ? It fades after about 3Kms
    Sorry for what could be a really daft question
    In Carport. R
    Try pressing the button next the the A/C button so it doesn't let outside air in.
      factory's forever happy water temp isnt a true indication...
        Yes - even though I've driven up and over Ayres Rock in 60 degree heat and then driven the Antartic Ice Shelf with baby seals for snow chains I've often wondered why the water temp never ever moves from a stoic 90 degrees.....
          Okay after driving on the highway most of my cars life so far here is the answer:
          1. Just because the fan isn't going doesn't mean the car isn't pumping hot water through the heater core
          2. Once you go above ~60km/h the air pressure coming in the front of the car pushes through the aircon system with the fan on "0". At 100 there is a fair bit of flow.
          3. Burning, you sit still with no air flow over the heater core in traffic. The aircon system is still heating the heater core. It gets very hot because you're car is trying to heat the cabin with no airflow.
          4. You drive off onto the freeway, you get airflow over your VERY hot heater core = heat plus dust/pollen = slight burny smell?
          That is what I have found driving 66km to work on the freeway each day.
          Originally posted by Kai
          And then dont forget the most important mod for gays.
          Blow off valve - 300
            Ben,
            Nail on head mate, thats whats going on here.....So nothink to worry about huh..Great!
            cheers for the explanation.
            In Carport. R
              a/c fan
              After my wife rearranged the front end of my car and i got the a/c regassed the fan doesnt seem to spin as fast as it used too.before u could hear the fan now u cant.can someone explain
                What's your temperature on? Maybe try turning it to the minimum? i.e. below 18.
                MY07 Polo GTI APR'd - Gone!
                  doesnt matter what temp u put it on the fan just doesnt seem to run as quick as it did be4
