The Official Polo Tyre Thread
	This is a sticky topic.
Hahaha just clicked over 50500 on the conti's. The past 5000km I've been trying to wear them out belting with the traction control turned off. I seem to be burning more fuel than rubber though.Originally posted by PeterHBne View PostBuggered if I know how some people get 40 & 50,000kms out of them.
						sigpicOriginally posted by KaiAnd then dont forget the most important mod for gays.
Blow off valve - 300
While you're sorting out your thoughts...Originally posted by Funkdancer View PostThread stickied! (Will edit this post to reflect my Eagle F1 tyres later.)
Car - 2006 Polo TDI
Rim Size - 16x6.5
New Tyre - Goodyear Eagle F1
Tyre Size - 205/45X16
Tyre Replaced - no idea - standard is 14" and i never saw them
Cost - $250ea
Km's On new Tire - 53,000km
Thoughts on New Tyre - Absolutely fantastic tyre. Excellent grip in the wet and dry - the polo is pushing through 290nm chipped and it grips and grips... The car's cornering is substantially improved from the one i test drove, however that was on 14" rims and whatever the standard tyres are on it, so it's not an apples to apples comparison.
Oh and 53,000kms... I am thinking about getting them replaced just because I'm uneasy about just how much ground they've covered...
Hehehe I bumped into a kerb at less than 5 km/h and detonated my Conti.
Just have to wait for my vouchers from my credit card to arrive and I'll be off to get some preceda 2's. I hope it doesn't take the full 28 days they reckon it takes for the vouchers to arrivesigpicOriginally posted by KaiAnd then dont forget the most important mod for gays.
Car - 2006 Polo GTI
Rim size - 16 x 6.5
New Tyre - Marangoni Zeta Linea
Tyre Size - 205 / 45 x 16
Tyre Replacement - Continental CS2
Cost - $184 each
Kms on new tyre - 1000 (approx.)
Thoughts on new tyre - Great in wet & dry. About the same road noise as the Contis. Tracked them at Morgan Park (Warwick) and most impressed with their handling.
Would I recommend them? - Without a qualm.
Longevity - I'll let you know.
Dave
Car - 07 Polo GTI
Rim Size - 16x6.5
New Tyre - Toyo Proxes T1R
Tyre Size - 205/45/16
Old Tyre - Dunlop Sport Maxx
Km's On Old Tyre - 40000km
Km's On New Tyre - 4000km
Toyos have better grip in a straight line and a smoother ride, but cornering is very poor. I'm guessing they are a softer compound and softer sidewall, cos steering is more vague (less feedback thru the wheel) and cornering grip is much less and a bit unpredictable. I think the tread just isn't as well controlled and squirms around more. The Dunlops were much more predictable on the limit in cornering, the Toyos unexpectedly and suddenly let go at a much lower speed than the dunlops. I have no confidence in them compared to the dunlops.
Car - 06 Polo GTI
Rim Size - 16x6.5
New Tyre - Michelin PP2's
Old Tyre - Conti Contact Sport 2
Km's On Old Tyre - 52000km
Km's On New Tyre - 400km
The conti's weren't bad, sidewalls were and issue and flexed around corners.
The PP2's have very poor straight line grip. I don't know if I have worn off the slippery layer yet, but out of the tyre fitter I ripped a nice 1st-2nd-3rd gear burnout. Still after 400km there is no grip. Cornering is great added 15km/h to my favourite corners and no sidewall flex
The Tyre dealer only put 30psi in them when they were fitted which gave me horrid fuel economy. I put my usual 41psi in the fronts and 38psi in the back but the car is still drinking 1L/100km more than before with the Conti's.
Overall I gained cornering at the cost of more fuel and less straight line grip.sigpicOriginally posted by KaiAnd then dont forget the most important mod for gays.
Car:VW Polo GTI
Rim Size:16X6.5
New Tyre:Federal 595RS
Tyre Size: 205/45 R16
Tyres Replaced: Michelin Sport Contact 2
KM's on New Tyre: 250km
Thoughts on new Tyre: Hello Grip!! So much less tyre wall flex. Throw it into a corner and feel the tyres grip and go. The tyres build up heat very quickly and hold it Very well. Corners don't lead into power under-steer. very easy to control. If you get any power over-steer, just back off a touch then plant the right foot again.Last edited by Blitzen; 14-06-2008, 03:16 PM.
How much did you pay for these mate? Always heard bad things about Federal's. Need to replace my Conti's as they have 35,000 on them and are stuffed! Was going to get PP2's but a bit $$Originally posted by Blitzen View PostCar:VW Polo GTI
Rim Size:16X6.5
Thoughts on new Tyre: Hello Grip!! So much less tyre wall flex. Throw it into a corner and feel the tyres grip and go. The tyres build up heat very quickly and hold it very well. Corners don't lead into power under-steer. very easy to control. If you get any power over-steer, just back off a touch then plant the right foot again.'07 Polo GTI - Stock
I got them for $300 each. I havn't heard anything bad about them either. My mate recommended them to me and I thought I would have a look.Originally posted by hummel View PostHow much did you pay for these mate? Always heard bad things about Federal's. Need to replace my Conti's as they have 35,000 on them and are stuffed! Was going to get PP2's but a bit $$
Noise and lack of wet weather grip.
Also, they cost more and only last about 10000kms.FOR SALE
"VW GTI" QLD Prestige Plate
