2006 polo gti engine light issue
  • 2006 polo gti engine light issue
    Hey guys,
    so I've owned this car about a week and a few days in I got a check engine light.
    I got racv to come out and check it and they said looks like the temp sensor got out of sync and reset it for me.
    2 days later I got the light again. The next racv guy said tAke it to a mechanic and get the sensor replaced.
    so I did and they replaced the sensor.
    3 days later (today) yet again The engine light has come on.
    Has anyone else has issues with this or any input on what could be causing it. I've read a few things like petrol cam not being on tight enough and setting off the emissions but honestly I have no idea.
    2006 POLO GTI -------RUS7Y-------Custom Cat Back + More to come
    Originally posted by RUS7Y View Post
    Hey guys,
    We can't advise you what to do on the small amount of information you have given us. There's a vast number of reason you could have a CEL lit.
    You need to have it scanned by someone who knows VWs. There's plenty of places around Melbourne that can do that.
    I'll be in Melbourne all week with work and will have my VCDS cable with me. Staying in the Docklands working nights at Tuallamarine.
      Some guy guessing is getting you broke, not fixing.
      Wouldn't have a clue without knowing the code thown, get it checked or buy a cable and check it yourself. Have a look at your fluids because its easy.
        So I had RACV come out again. He didnt give me the code but said the temp sensor was out of sync again.
        He cleared the codes and the car seems to be fine.
        I also disconnected the battery to give the full car a reset and to my surprise I think it is running a little better. But i could be wrong.
        Stupid HU though is asking for codes which i don't have.
        Im not too fussed as my new pioneer 2650bt is going in next week
          Your RACQ man isn't giving you anything here matey.
          Disconnecting the battery > Throttle Body Alignment (TBA) - Ross-Tech Wiki
          This procedure details how to perform a Throttle Body Alignment (TBA) on many VW/Audi vehicles. This procedure cycles the motorized throttle body through various states (idle, part throttle, WOT) to relearn their positions. Some examples of reasons to perform a TBA:
          The vehicle's battery has been disconnected and re-connected
          The ECU has been removed and reinstalled
          The Throttle Body has been cleaned or removed and reinstalled
          The Accelerator Pedal has been removed and reinstalled
          A temp sensor is a temperature dependent resister, it can go out of tolerance or fail completely. They don't go out of sync?
          I am in Melbourne all week from tomorrow, happy to look at it for you.
            Im so annoyed I didn't get to catch up with you Gavin my GF's mum went into hospital so we had to look after he little brother a sis as well as hit the hospital most nights.
            After a few more weeks the issue is still happening however I have surgically narrowed it down.
            I read on some forums that the issue could be the fuel cap sealing properly so for a week I never filled past $15. issue didn't happen still for around the 4 days.
            I then started recording my KM in my phone and came to a very surprising result. My check engine light is going off give or take a km or 2 every 240k's
            This is very very weird.
            It was really just puzzling me because if it was a major issue. once I reset the battery to clear the code I would expect the light to appear on the next trip.
            It is going into the mechanics in a few weeks (once I get tax back) for a major service + timing belt etc etc as hit has just hit 100,000ks and i want to know she is mechanically sound.
            Just thought id give an update.
            Hopefully its nothing big like a CAT and once the full service has happened she comes back purring
              You can get the ebay vag com cables for like $9 from china, or $15 locally and sent within a few days. They'll say they need windows XP to run, though I found newer drivers which overcame that issue - http://www.vwwatercooled.com/forums/...in8-98054.html
              A scan will provide further info. Otherwise find someone local with the genuine Ross Tech cable, there's plenty of members in melbourne with them.
              Daily: 2010 VW Jetta Highline
                Are the Vag Coms very detailed as in provides codes like a VCDS will? I'm looking to order one myself to see if anything comes up with my current issues I'm having..
                2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
                  Mate I'm over in Sunshine West if you need someone to have a look. Just drop me a PM, free most weekdays after 8pm or weekends.
                  Volks Handy
                    That would be great mate. Next time I get the light on ill shoot you a pm. Should be back on by the weekend I'm about 70k away from it if I'm right
                      Mine does a similar thing. The code it throws is P0441. I've been told it's from overfilling the tank too but my old polo never did it and I'd always fill it to the brim. My engine light turns itself on and off, I replaced the N80 a couple of times, it fixes the problem for about 6 weeks. The fact that it doesn't affect performance means I haven't bothered rectifying the issue.
                        Yeah Mine doesnt turn itself off.
                        I have to either need to get racv to come out and reset the code or disconnect the battery and then reconnect.
                          I can take screen shots for you over the weekend to compare. The autoscan feature didn't allow me to reset/clear the ECU and lacked some details as to the fault, but did identify it, though by going into the specific category (e.g. engine), it gave more details and allowed for reset. It lacked some of the details the genuine cable provided but gave the code and I think the issue (in my case "response too slow" re an o2 sensor).
                          There may be more useful input in the VCDS section of the forum. I'm very new to this stuff and only exploring it cos the light came on and I wanted to clear it. Once that's sorted I'll probably run it only occassionally for logging purposes for health checks.
                            Thanks mate a screen shot would be awesome. I've got one ordered anyway so will be good to see if anything with my thermostat comes up on it
                              I have also ordered one. Should come in handy
