i agree with you there but it is a turbo charged vehicle and requires thinner oil i would use what they recomend til 90k at least thats when the major service is tbelt tensioner plugs coolant oilfilter pollenfilter brakefluid airfilter and gearoil upon request at your own cost
10W 40 magnatec for the Pog mate no dramas there - i believe they now do a 5W40 which will be a great oil mate one of the 2 - thats my opinion.
I may be biased when it comes to Castrol though. Lots of good oils out there having said that i wouldnt use o weight though.
Alba European
And your point is???? You seem to know enough about the oils why ask the question???????
Alba European
Any reason why a 0 weight is not good? Would you say that it is not good for the engine or more that it does not make a difference between a 0w and a 5w seeing we live in a hot climate?
NickZ
Former ride: MY07 Black Polo GTI
Current: MY09 Blue Passat R36 Wagon
Ok its more important to use 0w or 5w on engines with variable valve timing as heavier oil can slow down the operation of the vario cam. Turbo engines from experience when they get up the ks turbo spools quicker with the lighter weight oil, im happy using Magnatec on Polo but if you are stuck on fully synthetic if you have been feeding the engine that from day dot thats the go - sorry for any confusion earlier post. I had an A4 APU 1.8T have 10w40 Motul all its life and the owner decided for winter we would do 0W. When the engine got warm the oil light came on - too thin. And the thing was a handfull as it had a Ko4 and spooled up quicker with the 0w 40. Now back to Castrol on this particular engine we then used 0W60 Castrol and it cured it.
Remember the first prefix is for when the engine is cold (resistance to flow) and the second is for when the engine is warm so up the ks 0w40 is a bit thin IMO. If you like the idea of 0w then go the Castrol Edge 0w60 and Supercheap is doing great deals at the moment, with the Easter sale and all.
Also heard of a Daewoo Nubira non runner due to the wrong oil, it pump up the lifters too much and opened the valves off their seats. after a few flushes it then ran when the oil pressure had settled again. Oil is a very interesting topic, and there is too many good oils out there now, its your preference but just bear in mind the weighting.
Alba European
Cheers for that, good to know, my engine is still new (13000km) so 0w40 I think is good for now. Once around 75000km plus thought it seems like a 5 or 10w would be the better option.
NickZ
