Polo Boot refuses to open!
  • Polo Boot refuses to open!
    Has anyone else had any issues with the boot on the polo refusing to open? You always find yourself at the shopping center trying to get shopping in the boot, unlock the car, and the boot refuses to budge! then sometimes its ok..
    Found myself in this situation at least a dozen times now, girlfriends polo has the same exact issue..
    Only way around it is to lock the car, wait a minute or two, then try again, until its willing, you will not get the boot open..
    Anyone know of a solution to this
    Cheers and Merry Christmas
    2016 Golf R, APR Stage 1
    2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
    Do you need to double press the button to unlock both doors?
    I have mine set to open both doors with one press, so the boot is always unlocked at that time.
      How do you change it Gav?!?
      Sent from my GT-I9505 using Tapatalk
      2006 Polo GTI | Custom 2.5" Downpipe | APR Stage 2 | H&R | 17" Denvers | Whiteline LCA Bushes | Whiteline RSB | K&N Filter | 312mm TT Brakes | RDA Rotors | Remsa Pads | SAI Delete
        I did mine with VCDS I don't believe there's another way.
          I have mine set to open the doors with one press, gf's polo is a double press but doesn't seem to make a difference..
            Spray some WD40 up into the locking mechanism. It might just be gummed up and not releasing
              I just use the key when the handle is not working
              Somehow the boot handle is using wire to control the lock not mechanical
              Weird design
              06 Polo TDi
                Noticed the rear boot handle gets a lot of dirt behind it, hosed all the crap out and sprayed some wd40 into the lock mechanism, no jams so far
                  Still having this problem with both Polo's, always seems to get you when you have just done some shopping, pet hate number 1 so far!
                  This is the culprit, yet to organize this part from VW, anyone know a palce to pick these up on the weekend, Part Number: 1t0962103Click image for larger version
                    This is the culprit, yet to organize this part from VW, anyone know a palce to pick these up on the weekend, Part Number: 1t0962103[ATTACH=CONFIG]12491[/ATTACH]
                    [ATTACH=CONFIG]12492[/ATTACH]
                    Hi flat6,was the abovementioned part (1t0962103) your problem,dit this fix the 'intermittent fault'.I am having the same issues with my 2013 polo Vivo GT 1.6.The boot lid wil have a 'no respond' issues every now and then.To climb into the back of a 2 door vivo is not that easy!!
                      Yes pick up that part from your local VW dealer and pull the plastic lining off the hatch, its a simple clip in replacement. Boot has been opening perfectly for about 6 years now. Probably due to replace it again soon haha
                        resurecting this, trying to get the part # for the following piece that i broke on the hatch
                        Blue circle is what i need the part # for.....the plastic dongle thing that clips in the actuator arm...
                        also the red bit does this just 'pull' out.?
                          Boot micro switch 1T0962103
                          Edit: sorry didn't read what part number you needed.
                            Sent from my LM-Q610.FG using Tapatalk
                            thanks, any ideas on how i get the little white plastic piece in blue circle part#.? i am going to try and pull the microswitch out (again) it is hard to see how it pulls out
                              improvised with cable ties for the interim, pulled the micro switch assembly and hitched it up higher to try and engaged the connections better
