We have had many a requests for the Polo GTI downpipe, so we have done the numbers on making a direct bolt on downpipe that can be used with the stock catback, or any other brand cat back out there.
Same quality, fit & finish as our full APR system. Double braided flex joint used.
The system will be 2.5" (we get low down losses from 3", so 2.5" is our preffered size).
We have the choices:
1: Eurospec 4 high flow ceramic cat - will not cause a catalyst efficency light & will work with any software, including stock VW software.
Flows ~ 20% higher than stock cat.
$1299
2: High Flow Metal substrate Core - MAY cause a catalyst efficency light to appear on stock software - no problem with APR software.
Flows ~ 30% greater than the stock cat.
$1099
3: High Flow Ceramic Core Cat - MAY cause a catalyst efficency light to appear on stock software - no problem with APR software.
Flows ~ 20% greater than the stock cat.
$999
It would bolt straight up, no cutting, no welding & 100% reversible (so can be taken off directly & resold)
Let me know what you fellows think?
$1299
$1099
$999
