Coolant level light.
  • Coolant level light.
    I have a 2006 Polo GTI and a couple of times the coolant level light has come on just after I have started the car.
    If I then restart the car it goes away. It has been pressure tested and there is no leak. What would it be and how do I fix it? Anyone else had a problem like this?
    Some say...
    Is it short of fluid, you didn't comment on that?
      The level seems to be ok. The light has only come on 2 or 3 times, but intermittently.
      Some say...
        You only need to drop 50ml to have the light come on. I top up 2-3 times a year, think I have a very small leak.
        for me its cheaper to buy a 5L concentrate and have 600ml in the car made up.
        lifetime supply
          Very good idea. Thanks noone.
          Some say...
            FYI, to anyone reading this thread about coolant, I saw this product linked as one of the few parts that meet the VW standards.
            Cant see the thread I saw this in, but the product page shows its G12 / G12+ approved
              The chances are that its a faulty sensor. I have the same problem in my Skoda and the dealership is replacing the sensor under warranty. If it were just a fluid level problem then the light would come on at other times. The symptoms of coming on once or twice after you start in the mornings and not for the rest of the day is typical of reports of the sensor issue. An alternative reported on some forums is to brush the sensor clean with an old toothbrush as I have heard it can be related to a build up of residue. Not sure where it is, sorry!
              MY2014 Skoda Octavia Ambition Plus Wagon, DSG, Capuccino, Tech Pack
              MY 2010 Skoda Scout Manual Silver -traded
                the sensor is in the reservoir, not an issue on our cars that i'm aware of. You only have to be 1mm under the line and it will read low, when the coolant is a litte warm, it will expand and thus the light does not come on if its been warmed.
                  King among men noone. Thanks very much for the info.
                  Some say...
                    The sensor is an issue across a lot of VW models including the Polo. Its been mentioned before on the Polo thread here. Also in other forums.
                    Coolant Light flashing on start up.
                    Club Polo Forum > Coolant warning light
                      Thanks for the help guys. I am not the most mechanically minded person. It has to be serviced this week so my mechanic can have a look.
                      Some say...
                        Hi everyone,
                        Mine does the same, however, when cold and before startup on flat ground the level is at the full/max line and no where near the empty line. Sometimes I can go for weeks without it coming on and sometimes it happens every trip. If you turn the car off and on again its not there anymore. Every time I drive (ambient temps between 10-40 degrees C) it always comes up to 90 degrees on the temp gauge.
                        I think it is a faulty sensor which unfortunately is fixed inside the bottle and so needs to have the whole bottle replaced.
                        Red 2006 Polo GTi : Forge Splitter - TIP - ITB - Forge Front & Rear Strut Bars - Dash Cubby - Fumoto Valve - Full Milltek Exhaust - PD160 Intake - K&N Panel - ECS Stage 1 Clutch - Seat RCA Bushes - APR Stage 1+
                          Whats a new bottle/resovoir worth?
                          Some say...
                            Mechanic said its a leaking radiator. Thankfully it is a very slow leak. What is a new one worth installed?
                            Some say...
                              I have been quoted over $900 by my mechanic to replace my radiator on my Polo GTI. VW quoted over $800, Red Devil have quoted between $600-$650 and Natrad say $545. However I don't know if Red Devil and Natrad will use genuine VW parts. Instead of calling VW for a quote on a radiator they looked it up in their catalogue and I am pretty sure they thought it was the same radiator used in the 1.4 and 1.6L Polos. Are they the same radiators and can you guys recommend me anyone reasonably priced?
                              Some say...
