Has anyone had any experience with the above?
After my last outing at Lakeside, it revealed a big problem with a combo of no weight in the rear and lots-o-lift.
Braking into the corners quickly you could feel the rear end get squirmy, and the rear also squirmed about hooking it along the straight around the dog-leg.
I like the idea of a rear wing for simplicity, but I wouldn't run it permanently and I'm trying to figure out a mounting solution that would let me return the car to stock if need be.
So in the mean time, I've turned my attention to the underbody and diffuser.
I'm currently trying to decide on the best material to use. Two thoughts: aluminium sheeting, or ABS plastic.
I would prefer to use the ABS plastic as it is potentially easier to work with.
Any opinions on if the ABS will have enough rigidity?
I'm also concerned with cooling. I'm thinking of running a naca duct at the front of the gearbox so that air can run down the exhaust tunnel and then out a vent in the rear..
I'm also contemplating removing the tub for the spare wheel and stitch welding a panel in the hole to allow room for a functional rear diffuser.
This is my end game --
