I did a search through the forum to see if there was any similar threads..
I know there is the Problems and Fixes thread but I think that we all need this specific thread!
The main purpose is to list the symptoms of your problem and if you've fixed it, list that also.
For e.g:
DESCRIPTION:
Creaking from rear of car.
SYMPTOMS:
Consistent creaking from the rear of the car only when driving.
Also when pushing down on rear end when stationary.
FIX:
Replaced rear shock absorber top mounts.
P/N# 1J0513353D x 2
DESCRIPTION:
SYMPTOMS:
Rear end creaking when going over bumps.
FIX:
Re-greased rear sway bar bushes.
DESCRIPTION:
Knocking noise in front end.
SYMPTOMS:
Knocking noise sounds like it's coming from the lower front right hand wheel well.
Mainly felt when turning left or right over bumpy roads.
I can feel it through the pedals and steering wheel.
TRIED:
New shorter drop links,
New strut top mounts and bearings,
Re-greased brake pad faces,
Replaced LCA bushes with new SEAT bushes,
No luck?
And continue..
For e.g:
DESCRIPTION:
SYMPTOMS:
FIX:
P/N# 1J0513353D x 2
DESCRIPTION:
SYMPTOMS:
FIX:
DESCRIPTION:
SYMPTOMS:
TRIED:
No luck?
And continue..
