vagcom cable (vcds) and error msg's
  • vagcom cable (vcds) and error msg's
    As most of you would know, i have had a cel on for a while now...and having just got my vagcom (thanks Tim), I logged the below errors:
    2 Faults Found:
    16795 - Secondary Air Injection System
    P0411 - 35-00 - Incorrect Flow Detected
    16804 - Catalyst System; Bank 1
    P0420 - 35-00 - Efficiency Below Threshold
    and we all know why we get these msg's. So I have cleared my cel, and reset my service light.
    I now need to understand how to use this, as there are quite a few different config's that you can play with...
    If anyone needs to borrow a cable, let me know.
    Polo 9n3 GTI
    1st one relates to SAI binning, the second one I've not seen.
    As for how to use, you can't really do much in Vagcom but clear them that I'm aware of.
      I wouldn't be too surprised if the front O2 sensor isn't shot. Could be downpipe related though I suppose. Best wait till the ECU has been on it's holidays to Queensland
        The one is the sai, and the other I think is related to the DP ( as Gav rightly stated)...
        I have logged quite a bit of info already on the apr flash (if anyone wants any info, let me know).
        Next will be the Cc flash for comparisons.
        It is amazing how much info can be obtained!
        And yip, the ecu is booked on a flight...looking foward to a good holiday
        Polo 9n3 GTI
          And welcome to the Dark Side
            Polo 9n3 GTI
