Polo Picture Thread
This is a sticky topic.
  • #46
    • #47
      God that looks frightening.
      Is that an AWD or just a front, either way that thing has massive road presence.
      • #48
        Specification
        Engine
        Cylinders: four in-line
        Fuel supply: sequential fuel injection
        Cubic Capacity: 1984 cm3
        Valve gear Soupapes: dohc, four valves per cylinder
        Ignition: electronic, Bosch MS3.1, with 128MB data logging
        Fuel requirement
        Engine Output
        Max Power ISO (kW): 210 Kw (282 Hp)
        Power peak: (r/min) 8250
        Max usable: (r/min) 8500
        Torque Peak: (r/min) 7000
        Transmission
        Forward speeds: 6
        Driven wheels: 4x4
        Front differential: Mechanical Limited Slip
        Rear differential: Mechanical Limited Slip
        Centre differential: Mechanical Limited Slip
        Clutch/Ambrayage: AP Racing twin plate
        Wheels and Tyres
        Gravel Rally wheels: 6.5Jx15 alloy
        Tarmac Rally wheels: 8J x 18 alloy
        Tyre size gravel: 195/65 R 15
        Tyre size Tarmac: 235/40 R 18
        Brakes
        Front calipers: 300mm ventilated discs with 4-piston Alcon
        Rear calipers: 300mm ventilated discs with 4-piston Alcon
        Hydraulics: dual circuit with balance bar
        Steering
        Type: Rack and pinion, power assisted
        Lock to Lock: 2 turns
        Suspension
        Front: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
        Rear: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
        Capacities
        Fuel tank: 70 litres
        Dimensions
        Overall length 3916mm
        Overall width 1800mm
        Ground clearance 170mm
        Wheelbase 2470mm
        Track front 1587mm
        Track rear 1587mm
        Weight
        FIA (minimum 1150kg) 1150kg
        FOLLOW US ON FACEBOOK
        • #49
          Great post Tim, some interesting info..
          • #50
            i know this is the polo pic thread. But CHECK OUT THE VIDEO!?
            • #51
              • #52
                I WANT ONE! Just one ... is that too much to ask?
                Dave
                • #53
                  Polo 4 Super 1600 Gravel
                  Specifications
                  Engine Petrol engine, transversally installed, water-cooled
                  4 –cylinder in line, 16 valves
                  Bore : 76,5 mm
                  Stroke : 86,9 mm
                  Capacity : 1598 cc
                  Power : 232 hp at 8750 revs
                  Max Torque : 200 Nm at 6250 revs
                  Engine management : BOSCH 3.1
                  Emission control : Catalytic converter
                  Lubrication system : Wet sump
                  Transmission
                  Gearbox : Sequential 6-speed gearbox (RICARDO),
                  Transversally installed, straight cut, non synchronized
                  Differential : Mechanical limited slip differential
                  Clutch : Sintered metal clutch (AP), hydraulic
                  Transmission type : Front-wheel drive
                  Complete Gravel Suspension
                  Front axle : McPherson-struts, triangular wish bone, adjustable antirollbar
                  Rear axle : Trailing arm axle, adjustable antirollbar
                  Damper : ÖHLINS with adjustable fast-/low speed bump and rebound
                  Steering : TRW power steering
                  In addition : Kit Gravel
                  Brakes
                  Front : Ventilated brake disks
                  (Ø 300 mm gravel)
                  Pagid brake pads
                  Rear : Solid brake disks (Ø 280 mm)
                  ALCON aluminium callipers front and rear
                  Pagid brake pads
                  Polo 4 Super 1600 Asphalt
                  Specifications
                  Bore : 76,5 mm
                  Stroke : 86,9 mm
                  Capacity : 1598 cc
                  Transmission
                  Suspension
                  Brakes
                  (Ø 355 mm tarmac)
                  Pagid brake pads
                  Pagid brake pads
                  • #54
                    Polo 4 Super 1600 Gravel.
                    • #55
                      Polo 4 Super 1600 Asphalt.
                      • #56
                        • #57
                          Nice pics, Maris. Man those are tuff looking lil beasties.
                          Dave
                          • #58
                            Where is the box that I can tick that says "yes please - order now".
                            Originally posted by Whubbsie
                            • #59
                              must...get...oz...racing...superturismo...wrc's
                              • #60
