My rotors have a decent lip on them and will probably need replacing when I do the pads next. I'm happy to stay with stock 288mm rotors and I'm glad that comments from a few of the guys on here back them up.
Eddy when you say that the standard setup works really well , by that do you mean the factory VW rotors in particular, or that its the stock 288mm diameter that is fine?
One of the things that was suggested to me by a local VAG specialist shop was that the metallurgy of the VAG product is superior to a lot of aftermarket stuff and that a good way to improve stock rotors is to machine slots into them. Anyone opinions on that?
I always thought that the VW rotors were designed to wear with the pads compared to say Japanese OEM setups. Is it Ok to use aftermarket pads on stock rotors and not introduce really bad rotor wear rates?
