Weird sounds
  • Weird sounds
    When I was driving home from work today, I heard a chime coming from the dash board, like the door ajar warning, but it only went off once, no warning lights showed up , and I was cruising on the freeway, got slightly over 1/4 tank of fuel left, trip computer said I could do another 110km, so it wasn't the fuel warning... any idea what it might be? I think it happened a few days ago as well, but I didn't pay attention to it cos I was hitting boost...
    also, when I put the car into reverse, there is a sound coming from the aircon area, it sounds like the aircon is adjusting temperature or outside/inside air intake, why is that? anyone?
    puzzled...
    I had the chime too, thought it might have been the "fatigue warning" they have advertised but alas it turned out to be the RNS510 letting me know that it couldn't find a gps signal or that the traffic management system was not working (it never has worked)
      but my car isn't equipped with the RNS510 unit...
        I just had the same thing happen to me this afternoon. The missers mentioned the dinging as well. When it happened this afternoon, I noticed 'No TP' flash up on the radio. So I pressed the TP button on the stereo and it's gone. So far so good... No idea what TP is
        Polo GTI MY2008
        Build Thread
        136.09kW and 305.28Nm torques, Dynapack Hub Dyno
          Without stating the obvious it could be the service reminder if it's happening when you're getting into the car/starting it up
          Australia’s Largest Car Parts and Car Accessories Store.
            What was the outside air temp? It chimes when it drops to 4 degrees C and below.
              thanks, indeed it was -4 when i drove home last night... only in Canberra... mystery solve...
              what about the noise when putting the car in reverse? it sounds like the aircon unit is adjusting something?
                When you go in reverse the aircon automatically goes into recycle mode so it doesn't suck in exhaust.
                  The tyre pressure light chimes sometimes too...
                    or that noise/chime when you put the back seats down. Are they clicked in properly.
                    Any yeah, the air con goes to recirc when you grab reverse.
                    Daily: 2010 VW Jetta Highline
                      Can't say I get that noise, and my back seats are down quite often with the bike in the back
                        hmm, i get a chime when I unlatch the rear seat. There's a small button behind the drivers seat, about rear seat passenger knee height, not sure if that's a swtich for the chime or not.
                          i reckon that little button is about disabling the internal motion sensor for the alarm. so if you keep a dog in the car, its movement inside wont set off the alarm. never played with it though.
                          06 Polo GTI
                          standard ECU, wheels | K&N Panel filter | PD160 intake tube and trumpet |Nulon 5W-30 | Michelin contact sport 3
                            Yeah, never had the chime in regards to the rear seats down.
                              ahhh yes I have heard that before now that you mention it.
