what kind of mods can be done to my polo, can u fit a air filter (pod filter)? is der chips etc??
also needs to be lowered, curently on A8's.
its a 1.4L
i think the 1.4 16v can be chipped and can be fitted with different induction (pod filter).... not a bad little engine so i've heard, im pretty sure 100hp is pretty easily attainable out of them...
correct me if im wrong here...
VW: it aint just a car, its a way of life There are few things more satisfying in life than finding a solution to a problem and implementing it
i couldnt answer you without getting elbow deep in the Polo's engine bay.
i assume you find the original airbox, remove it and place with a pod filter
Well atmo engines its all about how much air you can get in and how much exhaust you can get out.
I'd do intake, so a pod, maybe some less restrictive piping.
Chip: Take advantage of more air
Exhaust: Just get a bigger system or higher flow mufflers
Engine, maybe bigger injectors.
That'll get your flogging along nicely.
Originally posted by Kai
And then dont forget the most important mod for gays.
Blow off valve - 300
so is this your new car? have you gotten rid of your passat?
yeh thought dis lil polo would look agrresive, it does okish smokeshows
hell my 1.6 8v does a good smokeshow, albeit single spinner
nah der doesnt see to have any room for a pod filter.. all the engine covers cover it up and they would have 2 be removed for it to maybe fit.. and look ugly
