hi guys i want to amp my standard speakers in my polo gti. i have a 4 channel alpine amp from my old car that will do the trick. Has anybody here done this with the standard HU? If So how many RCA outputs does the standard HU have? EG: FRONT+REAR+SUB OUTPUTS
Output On Standard Hu
last week , i helped out on a mate's car with standard HU hooked up to a 4 channel amp...
as said before, all you need is a line converter and wire it to the back of the headunit where your normal factory cables were...Theres no sub output, so you'll have to just use the same line for the front and sub.
Originally posted by chrisgti View Postdoes the mk5 gti golf 6 stack head unit come with rca outs? ive got a factory external stacker so im assuming that'd be an rca in set? i wanna run an amp for front splits and sub..
Dave
Hi,
In Malaysia, there's some continental cars install some kind of converter to the existing hu. This I think allows you to run multi amps configuration say running full active setup on drivers & and monoblock on sub.
Anyway, do you know which company supply our stock speakers? I found them pretty good except sound separation and staging.
Speakers - Phillips Europe.
You're in need of a hi/low inverter which allows the RCA's to connect to your amp. Previously did it when I was only running a 2 channel Audison SRx2, powering a Hertz ES250. Personally suggest you go the extra yard and get a decent HU installed for more audio enjoyment.Last edited by Celestine; 13-07-2008, 12:13 AM.GTI|BBS|Forge|Whiteline|Custom CAI+K&N|Sparco|Toyo|Martini|JVC|Focal|ScanGaugeII
