Polo GTI 06 owner please come in
  • Polo GTI 06 owner please come in
    Can you cd player play mp3 file format CD
    THANKS!
    06 POLO GTI RED HOT
    Yes, mine does.
    In all seriousness, your head unit should have "MP3" stamped on it, just above the CD slot. If it doesn't - your head unit is not MP3 compatible. If that is indeed the case, I'd be looking in the boot next to the spare tyre to see when exactly your build date was.
    You might be looking at an '05 rather than an '06.
    Just as a question - have you encoded your MP3s with Variable Bit Rate? I'm not 100% sure if the Polo's head unit can handle that. I'd be surprised if VW swapped head units in the middle of a production run (assuming you do have an '06), and think it's more likely there might be an issue with the CD in question.
      Mine is 2006 model buy built in 2005
      I cant play mp3 file as i have tried many times.I am very sad about it!! is there any way to upgrade it?
      06 POLO GTI RED HOT
        This was a feature added on later models. Mine was built sep 05 and does not have the mp3 player.
          THANKS!
          mine was built on the 1st(i think) jan 2006 n it has mp3
            Mine does ... even has a little mp3 sticker on the unit.
            Dave
              Mine was built 11/05 - i can play MP3 files here, VBR too im pretty sure, i recall seeing some mp3 cd parameters in the user manual, about how to burn the disc eg no more then 8 folders or something etc, have you checked those to make sure your cd is ok?
                I cant find any sticker on my unit.......
                so ....
                anyway, is tehre any possible that i can link the audio system to my ipod?
                06 POLO GTI RED HOT
                  I read a German forum the other day on the various models of radios fitted to Volkswagens, basically it said that the base CD version is capable to play DVD and MP3 music formats on any once the update disc is loaded into the system.
                  It appears that most current spec radio systems are capable of the upgrade and the upgrades should be available from your VW service areas. If they don't have it then it is available to download via their VW TIBs.
                  Ask your dealer to see if it can be fixed and if no joy approach VGA at 6 Lord St Botany NSW (02) 9695 6000. If you make the noise they will hear you.
                  Flipper
                  Flipper Dog
                  Now - T-Roc R, Audi Q5
                    Mine was delivered in Feb 2006 to NZ. It has MP3 tag on it, and has no problem playing them at all! I made CDs with NERO burning ROM.
                    No problems. Just remember to use good blank CDs (like Imation, or Sony or something reputable), and not on DVD!
                    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
                    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
                      Does anyone have cd-reading sounds coming out of the CD player? I haven't tried an audio CD yet, but with all my MP3 CDs, I get blip noises coming out of the unit. This noise is clearly audible when the volume is low or mute. It is getting really annoying, and I was wondering whether this is a fault. Does the CD have to be burned at certain rates?
                      '07 CW Polo GTI
                      'Roof::Leather::Tint
                      GIAC::Whiteline RSB + FSB::Forge SB:ogbone
                      Glossy B::Cubby::Honeycomb::Antenna
                        Mine is the same; I actually wondered about this one: Is it a 2006 model Polo or a 2005 model one? Actual dealer delivery to previous owner was December 05 or so.
                          I balive after 2005 Aug its the 2006 model? could be wrong tho.
                            Mine's 2006 and plays MP3s no trouble.
                            Dave
