Hi guys!
I have had alignment done again (after I asked the dealer to do it for me prior to the purchase, I don't even know if this has been done) today.
I told it to the guy who was doing the alignment (very knowledgable guy..) and told me that in that case, the alignment is very unlikely fix the problem, and the problem lies with the camber.
He told me that Polos are not camber adjustable. Anyway, he put the machine on the car, and toe was only off by little bit, and camber was different by 0.8! (i think -0.28 and -1.0
He took it for a drive, and said the pull to left is quite a lot. And looked underneath and recommended to call VAG and ask if Polos are 'cradle adjustable'.
He took the car down, changed the wheel from left to right on the front, also tyre pressures again (found a nail in one which was setting my tyre pressure sensor off every 3rd day). This improved the pull to the left, and when put on the machine along with some toe adjustment, reduced the camber finally to -0.28 and -0.68.
He said that's best he can do at this stage. Took it for a drive, and massive improvement. Now with the wheel centred, on flat surface (with almost zero camber on road), the pull to the left is very minimal with less need to fight or compensate it. This has now definately improved torque steer.
He reckons that he has seen many European cars being sold in NZ with 'pull to left problems' which would work fine in LHD roads!
Have you guys had these problems before? I had a Mitsubishi Airtrek Turbo-R which had a slight pull to right also.
He recommended to get tyre pressure checked regularly, and recommended that next time I get tyres get 'uni directional' as some directional tyres can worsen the problem.
Any solutions to this? Is Polo cradle adjustable?
Thanks guys!
(oh yeah I did search through forums prior to posting)
Thanks guys!
