Reverse + Fan
  • Reverse + Fan
    Hi Guys
    Quick question. WHen i put the car in reverse i can hear a fan turn on and its coming from the passenger side.
    I only heard it for the first time this week.
    I have had the car now for 3 months.
    Only mod is a BMC panel filter.
    Just curious
    its normal. they all do it. beleive its to do with the change in airflow due to reversing but not 100% sure on its actual effect....
    2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
      If it's like a Skoda, it is opening the recirc flap to reduce the amount of exhaust coming into the car. Should also happen when you use the windscreen washers
        I think you are correct.
          My Golf does this for the exact reasons you list so wouldn't be surprised if it's a standard VW thing. It outlines it in the manual, take a look and see if it's in yours.
          MY07 GOLF GTI
          5-Door l Tornado Red l DSG l Leather l Xenons l MFD2 l TCP T.B.E l DNA stage 1
            It should also give you a courtesy wipe on the rear windscreen when the wipers are on.
              Yeah mine does this
                Yep... so for those obviously too lazy to read the owners manual, you can confirm that this is the case by just sitting there in neutral and turning on recirc on the aircon. You'll hear the exact same fan noise
                  Lol...This so needs to be said more often!!
                    Thanks guys... And yes i was to lazy to read the manual.
                    Cheers though
