Hey guys,
On the way to work this morning -- it's a really wet couple of days so far in Sydney -- the power steering light came on, and I've no longer got power assisted steering. While I don't really mind during actual driving, parking is a real bitch.
A bit of quick Googling while pulled over yielded this thread, which talks about a poor connection throwing an error code. I turned the car off and turned it back on, making sure to let it run all the pre-flight checks first, and the light went off for a couple of minutes (during which time I had power assisted steering working), but came back on.
I'm guessing it's either the PS fluid level, or a faulty connection. More expensive would be the sensor or the pump itself... But to start with - can anyone let me know the rough price or VW part number for a fresh batch of PS fluid, and the location of the PS pump/sensor so I can check connections and lube things up to make sure it's not throwing a faulty signal?
Edit: I've also found this thread from GTI Dave. Hope I don't have to replace the pump, since the car is only about 9mths out of warranty.
Cheers!
Cam
Cheers!
Cam
