OEM to Performance Clutch?
  • OEM to Performance Clutch?
    Hi Guys,
    Considering putting an ECS Stage 1 clutch in the GTI.
    Will this one fit?
    Volkswagen Golf IV 1.8T > Drivetrain > Clutch > ES#125 VW Stage 1 Clutch Kit (228mm) With Light Weight Steel ECS 14lbs Flywheel, 225-275hp - ESR198031S1
    Is it worth paying extra for the 14lbs Flywheel rather than the 20.5lbs Flywheel?
    2020 VW Golf R
    Also, is there anything else I should be replacing at the same time?
    2020 VW Golf R
      i got the stage 1 with 14lbs SMFW. the only prob i had was the release bearing was damaged during transit. I only found that out AFTER i had removed the G/box and old clutch. The stage 1 is great. clutch pedal felt lighter and more responsive. Engine response felt the same. there is a noticeable gear rattle at idle but once you push the pedal in it goes away. Im not too fussed about it.
      APR V2 | APR Downpipe + custom catback | APR solid mount | FMIC | SEAT intake | BMC filter | FORGE 007DV | KW v1 | WHITELINE RSB
      139Kw | 271.8Nm atw - At a new home
        I went to the ECS site and the postage is nearly as much as the goods themselves, if you order 2 clutchs/flywheels the postage is halved.
        I would probably be interested in a few months or so, I dont really need it yet, but seeing as the $$ is so good now, why not
        MODS- TOO MANY
          $540.82 USD for 1 or $934.50 for 2
          Which is $883 AUD /2 is $441.50
          MODS- TOO MANY
            If you get more interest and can find someone locally to get it at a better rate, could get very cheap.
            I'm interested to hear more about the rattle, is it audible outside and inside the car? How loud is it? Does it rattle on the MkIV?
              Locally I think just the Clutch costs more than the Clutch and flywheel combo, I remember paying around $500 just for my VR6 clutch kit, I dont know who would sell a 14lb flywheel locally
              MODS- TOO MANY
                I'm finding out the shipping weight, I usually use a US shipping service so i'd like to know how much that costs as an alternative.
                Maybe we could do a group buy though? Post if your interested?
                2020 VW Golf R
                  Anything over $1000 gets inport duties/taxes, so best to keep it under $1000
                  MODS- TOO MANY
                    Why are you looking into this? You've only just got the car!
                    Unless the clutch is failing, there are far better places to spend money (like trackdays - hint)
                    Resident grumpy old fart
                      Im suprised that the car has lasted 80,000km with the standard clutch, seeing as it has the APR tune and it did have a downpipe
                      MODS- TOO MANY
                        If it ain't broke, don't fix it (I was about to make a comment about the occupation of the previous owner..).
                        Just flog it 'til it breaks (like at a track day - hint) and THEN fix it
                          Hmmmmm some of us like spending $$$ like me
                          MODS- TOO MANY
                            I don't think any of my upgrades were to replace parts that were not working...
                            If it improves the drive, why not.
                              Lol! Well, I figured I might as well strengthen it now
                              2020 VW Golf R
