Originally posted by Eddy
View Post
Caster Discussion
Hoyhoy.Originally posted by vwthunder View PostThey are custom, can they make another set, guessing they are not cheap, also with the APR K04 tune, is it agressive, what does the boost peak at (psi)
When I say custom, I mean very custom, a lot of my own hours fiddling.
Boost spike is up there.Hooroo.
Sorry mate, thanks for clarifying. Not sure why I thought you had K-Mac's. Did you look at the K-Mac's?
Anyways, it would be great to get your feedback and some more input from you Eddy as you are the only one who has done this on the Polo / Cupra that I've seen.
Has it added any noise? Would you happen to know if the K-Mac's would work?
Van has the Kmac's on his polo, maybe you can PM him, I have spoken to him about this and he says that there was not really a noticable difference, then again, his car is quite loud and he is running 18's
With the Kmac's there is cutting involved tooMODS- TOO MANY
Have a look here
Im not sure if the Mk4 gti have the same strut tops as a Polo
VWVortex.com - MkIV Camber plate list
Everyone says the Ground Control are the way to goMODS- TOO MANY
Hoyhoy.Originally posted by noone View PostSorry mate, thanks for clarifying. Not sure why I thought you had K-Mac's. Did you look at the K-Mac's?
No extra noise, I decided at the time that K-Macs weren't what I wanted.Hooroo.
Hoyhoy.Originally posted by vwthunder View PostVan has the Kmac's on his polo, maybe you can PM him, I have spoken to him about this and he says that there was not really a noticable difference, then again, his car is quite loud and he is running 18's
I think you'll find that there will be cutting with any adjustable camber set-up.
All ya have to do is cover it up.
http://
http://
Hooroo.
I've got the SuperPro eccentric ones in mine.
Very firm, bloody noisy and squeaky though!
The extra turn-in is a nice improvement without being silly. Mine is a street duty car which sees many miles.
NOTE: I have only done springs and dampers in my car. I have no rear swaybar.Cheap, Fast, Reliable. Choose two.
I guess you mounted it taking advantage on caster.
Did you tried the White Line or any other similar? Just to make a comparison.
I´m having this problem with the lower control arm in my car. I´m using White Line.
Pay attention on the front wheels, when braking, the bushings are yielding so probably when making turns the bushings are not holding as well.
Originally posted by Stuwey View PostI've got the SuperPro eccentric ones in mine.
