Forge TIP
  • #46
    Originally posted by hkogti View Post
    There are no clamps with the TIP, do i need to go get some beforei start install it?
    I looked at it a few time and it is too difficult...
    Yeah mate you need to get the clamps before you start. A few posts up i have got a full list of the clamps you need. And it's also posted in the faq thread. Personally it's more fidily the dificult. The 2 tricks I was told was to use soapy water as lubricant when putting the TIP on the turbo as when it dries it won't leave any residue. And the second was to undo the water pipe running along the side of the motor, it's an allen screw. Sorry I don't have any pics. And this gives you a tiny bit of leverage. Other then that take your time. Its not tooooo dificult
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    • #47
      Alright...
      I am going to get those clamps on sat morning and try to get it done during the weekend...
      wish me luck...
      my other friend said it looks like a few hrs job rather then 40 min...
      • #48
        i may not own a polo gti but i do own 2 mk4 gti's both chipped and everything else but exhaust.
        Doing the Samco TIP on my GTI made a difference, but once installed the Thermal power gasket on the intake manifold. That is where it really made a difference. Car is getting alot cooler air intake temp and car pulls really well.
        the Girlfriends GTI has Full Forge TIP and all intercooler hose kit. Also made a good difference. But now still need to do the thermal intake gasket on her car.
        Audi S4 (2001) - Imola Yellow
        Secret Project
        • #49
          Hey Shane, why can't you use the old clamps that came with the car on the new TIP? I'm just curious cos thats what I was going to do when I got the TIP.
          • #50
            Yes i dare say it will take you more then 40mins i know it did me on my first attempt.
            Mate not sure if they all will fit. Im 99% positive the clamp that holds the TIP to the Airbox wont fit. And personally i would prefer to replace them just for piece of mind. And as i havent tried it myself im not going to tell anyone else to just in case. And for $10-$15 i know what i would do.
            I know none of the ones i have done have been single use only............ Try it and let us know.
            Have a Look
            CUSTOM CODE
            Phase 2
            • #51
              Originally posted by shaneth View Post
              Forge Turbo Inlet Pipe Clamp Sizes
              Screw Type Clamp
              3 x 11 – 16mm
              1 x 17 – 25mm
              1 x 25 – 35mm
              1 x 40 – 55mm
              1 x 60 – 80mm
              I cant get a 60-80mm clamp, can i use a 65-90 instead? It looks too big for the tip...
              • #52
                Yeah It sounds like it would be ok. And yes you are right it does look big but once it goes over the air box it's different. You'll see what I mean.
                Have a Look
                CUSTOM CODE
                Phase 2
                • #53
                  Tomorrow will be my 3rd attemp to get it done..
                  Wish me luck!
                  Tried 2 times and cant get the hose out!!!
                  • #54
                    Wish me luck!
                    3rd times a charm??
                    I was too lazy to do it myself.... esp after all the write ups, I just got someone else 2 do it.
                    Good Luck.
                    T Go
                    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
                    • #55
                      Hahaha...
                      i think i m too weak, i got small hands and skinny arms, so getting there is not a big issue, but seems that they are not enough space for me to use force to get it out...
                      • #56
                        Ill pm you my number. Give me a call causefrom memory it shouldn't be to hard to get off. Getting on is fun though.
                        Have a Look
                        CUSTOM CODE
                        Phase 2
                        • #57
                          Hey Shane, when do you think the next batch will be in?
                          • #58
                            Told me 4 hrs and finally got it!!!!
                            I end up took out the whole gear box to pull the thing from the side!
                            One thing i noticed is the hose is so fat, it now pushed 2 stainless steel cables down a bit, what cables are they? Does it matter to leave them bended?
                            The induction and turbo spining noise is much louder!!!
                            Car is more willing to rev and better top end, also noticed that intake temp have drop!!
                            Forgot to mention i did the seat intake at the same time!
                            • #59
                              If any one wants to buy a new black Forge TIP - I have one for sale... Keen to sell!
                              JCM
                              • #60
                                I just wonder if I can bring up this topic again?
                                I was talking to a mechanic today about the Forge TIP install and he commented that the pipe squashes up against that water coolant pipe that you have to loosen the screw to move. I have never heard anyone comment about the pipe resting against this water pipe.
                                Has anyone had any issues or does anyone see any issues with the TIP resting against the water pipe?
                                APR V2 Tuned, APR Dogbone mount, APR R1 DV, K&N Panel Filter, SEAT Intake, Forge TIP & FSB, Bilstein & H&R, Whiteline RSB, Full Milltek 2.5" exhaust
