The other night when i had a nail in my tyre i ran into a problem. I had the car on a jack, wheel nuts off and already to take the wheel off and when i went to take the wheel off it didnt budge. Now ive had this before where the wheel rusts to the hub, and normally you just give it a tap and it comes off. But this time no, gave it a yank and a kick and nothing. obviously i was carefull of the car coming off the jack and i also had a spare wheel under the car just in case it came down. Anyway i rang VW assistance and they said if nothing i had done worked then the only other thing they suggest is
"to put two wheel nuts in (opposite sides) so its finger tight, then loosen the nuts a full turn. Then go for a drive if you can in sharp turns and itll break free." This worked a charm, so i just thought i would let you all know in case it happens to you at some stage.
