Hey guys, so I've two separate issues. One is finding out where this oil leak is coming from. I say leak, but it'd be more accurate to call it an ooze. I've wiped it down as best I could just to see if there was any drips. No marks on the ground of anything dripping, but it does appear to be oozing a little bit from somewhere.
Centre of the image and bit to the right, you can see the oil hugging to a chunck of metal. Is this where the transmission is located?
The second one is the knocking I'll get every now and then when turning a corner at low speed and the ground is a little bumpy. I've read that our control arm bushes aren't the greatest so I took a pic to get some feedback on whether these bushes are still in good nick or if they could be causing the sound. The only problem is, it's almost impossible to simulate.
The car has just hit 22,000km.
