oil pan cracked!
  • oil pan cracked!
    last night, on a dimly lit road, went through a big, deep pot hole and after jacking up, the oil pan is cracked and leaking engine oil no other damages detected, driving and drive train characteristic seem normal, no funny noises.
    i've been searching on the web and this came up for 1.8t oil pan.
    VW Polo 1 8 Oil Pan Sump With Oil Level Sensor Bore
    i'm pretty sure ours come with an oil level sensor on the oil pan.
    the OEM VW p/n is 038-103-603-M.
    is this the right one for the pog?
    cheers
    pics:
    where the crack is. it's a vertical crack originating from the drain plug hole.
    this should be the oil level sensor, no?
