Originally posted by flat6
View Post
lower honeycomb grill for polo gti
AhhhOriginally posted by Blitzen View PostYep, right after you pull the front bar off the car.
looks like ive got something to keep me busy this weekend
The bumper comes off relatively easy doesn't it? couple screws and it simply pulls out?2016 Golf R, APR Stage 1
2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
Do the lower side ones have any clips holding them in? I know of the screw holding in the drivers side one, but both of them just won't pull out.
I'm contemplating doing a full bumper removal, but for a first time DIY, it's not something I want to undertake lightly.2008 Polo GTI, lower honeycomb grills, PD160.
I just finished my honeycomb grill installation, had to remove the front bumper as they really do clip that middle grille in with a vengeance, you need to remove it with a flat blade and some forceful knocking.
Unfortunately you cant avoid removing the front bumper but after about 4 hrs of screwing around you will eventually figure it out, use the guide i posted above.
Tip of advice, when putting the bumper back on, align the little clips beneath the head light and use your palm pushing in whilst fitting it its really this simple.
Am loving these honeycomb grills, it just completes the car, the wind deflector for the turbo intercooler doesn't clip into aftermarket grilles, i had to screw mine to the new grille using tiny screws.
Does the job
I gave up attempting to remove them for the time being, and am now clearing out the blocked off honeycomb sections, This is going to take me hours, but the end result will (hopefully) be totally worth it.2008 Polo GTI, lower honeycomb grills, PD160.
Starting out I had no idea, and was just cutting at the areas with a stanley knife, then start drilling large holes in the middle....Originally posted by flat6 View PostYeh cutting them extra holes out cleanly took me the better half of friday night, but totally worth it...
Suffice to say, I now have it working out to small holes in the corners of the honeycomb, then stanley knife along the edges = smooth streamlined process. I hope to have some time tomorrow night to finish it all off. Then I can start to think about removing the front bumper. That forge guide has been quite helpful, I just need to track down some T25/T30 screwdrivers.2008 Polo GTI, lower honeycomb grills, PD160.
I'm thinking of removing the bumper tomorrow now that I've found some TORX screwdrivers.Originally posted by flat6 View PostI just finished my honeycomb grill installation, had to remove the front bumper as they really do clip that middle grille in with a vengeance, you need to remove it with a flat blade and some forceful knocking.
Question though, do the front wheels need raising on stands for the bumper removal?2008 Polo GTI, lower honeycomb grills, PD160.
