Wiper washer fluid
  • Wiper washer fluid
    Accidentally pulled back on the right stalk the other day and thought "Oops, no big, at least the fluid will spray up and not wreck the wipers". But no, there was no washer fluid. The wipers did its two/three cycle thing. Popped the bonnet when I got home and noticed the fluid is about 1cm below the mesh screen thing. I have never used the fluid before, is there something i need to do to "activate" the fluid jets?
    MY07 Polo GTI APR'd - Gone!
    If you just pull back on the stalk momentarliy, then it might not be sufficient for the pump to spray.
    If you have pulled on the stalk for a few seconds and there is no fluid and no noise, then chances are that the pump is rooted or never been connected. Then you will have to take it to the dealer for them to fix.
    He who dies with the most toys wins!!!!!!!!
    2000 Golf 3.5 Cabrio lowered, low ratio box black-on-black-on-black
    2010 Tiguan TDi Manual Stage2 tune, DPF delete Egr delete
    2008 Jetta BWA DSG Stage 2 tune, 3"VF intake
    Formally known as WA 79 cabby
