Hoping someone might know what the problem could be with the auto transmission, when I slow down and then accelerate without coming to a stop, the gear box sometimes gives a hard "bump", also sometimes it would take a second or two to select the correct gear, causing the car to jerk slightly. What would the fix be, if any?
Auto transmission help
Change the oil and screenOriginally posted by parraeel View PostHoping someone might know what the problem could be with the auto transmission, when I slow down and then accelerate without coming to a stop, the gear box sometimes gives a hard "bump", also sometimes it would take a second or two to select the correct gear, causing the car to jerk slightly. What would the fix be, if any?
JmacAlba European
